Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 15, 2009, 10:34 AM   #91
Personal Sales Rating: (0)
jer301's Avatar
Drives: 2009 Lancer GTS
Quote:
Originally Posted by dustyp34 View Post
Same here. I couldnt even begin to tell you what a torque wrench looks like I never used one although Im from the country(Southeast Louisiana) and we judge everything by feel.
I'm with you guy's 22 to 26 ft-lbs is not that much. I would say using a rachet and tightening it should be fine. If you check your fluid and inspect your oil pan regularly, you should detect any leaks. As far as the gasket, I am on the fence. I don't think helps or hurts.
Offline
Old Sep 17, 2009, 08:19 AM   #92
peanutboylancer's Avatar
Drives: 2009 mitsubishi lancer gts
i think in order for you to switch to synthetic oil, you need to drain out the old oil and change the oil filter then switch it to the synthetic oil, the best oil i think is the eneos 05-w20, thats what im using and it seriously does better than those american oils
Offline
Old Oct 3, 2009, 12:36 PM   #93
Solofantasy's Avatar
Drives: 2009 Lancer GTS 5spd
need help. I dont have user manual.
So how much oil do we put per oil change for the 2009 GTS 2.4l engine???
__________________
Tarmac Black
Offline
Old Oct 5, 2009, 09:22 AM   #94
EngRWW33's Avatar
Drives: 09 Lancer GTS M/T
I put in about 4.75 qts to fill up.
Offline
Old Oct 12, 2009, 04:38 PM   #95
The Mitsubishi Car website said 4.5 qt..... But I added 4.3... it was not full at all, not even near full. what the heck?
__________________
Tarmac Black
Offline
Old Oct 13, 2009, 05:52 PM   #96
I know my 2.0 liter lancer takes 4.3 liters and since yours is the GTS I'm guessing it's the 2.4 liter which will take even more oil. Also double check the numbers you're reading on the website are in quarts or liters because that will also make a difference. If your oil is reading minimum on the dipstick you'll probably have to add about another half a litre.
Offline
Old Nov 6, 2009, 03:13 AM   #97
Drives: 2008 Lancer GTS
anyone know if the scheduled service of 30k mi. for a 08 gts can be done at home?
i called my local mitsu dealer... and they charge $248 wth
Offline
Old Nov 6, 2009, 03:25 AM   #98
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
^lol - anything can be done at home. For the Evo IX they want somewhere between $600 and $800, depending on the dealer.
Everything for 30k is easy though. Mostly fluids and maybe a belt or 2 (not timing!).
BTW - for those that don't know what a torque wrench is, it is usually a long socket-style ratcheting wrench (only tightens of course). There is an adjuster in the middle so you can set the ft-lbs, in-lbs, newton-meter, etc. When you reach the specified amount it will "click" letting you know you're there.
There are older styles that literally have an analog gauge where you will see the torque you are cranking. Those can be pretty inaccurate though.
22 - 26ft-lbs is tightening a nut to the point where resistance pretty much stops normal cranking, then one small "push" and you're there. You should be able to "pop" the nut back from that torque setting with little effort so if you can't turnaround and do that, you went too far.
Offline
Old Nov 6, 2009, 03:32 AM   #99
yahu's Avatar
Drives: 06 Evo MR
For those of you not seeing a gasket/washer on the drain plug, is it possible you're losing them in the oil that releases? I thought my rear diff drain plug didn't have one as it looked like there was a thin one built onto the plug. I went to dump my oil and found the little som' batch!
Offline
Old Nov 7, 2009, 07:30 AM   #100
Mark Hubley's Avatar
Drives: '08 Lancer ES
I did a nearly-complete write-up on the topic. Here's a link to the thread (or search my username):
DIY 30K mile service
The only thing I did not do at the time was check the oil level in the manual transmission. This requires a very large socket, and I did not have the right size at the time. I forget what the measurement is, but once you get the right size socket it's pretty easy. One of the follow-ups to my 30K post has a link.
By the way, my '08 ES should be all the same here as your '08 GTS. Unless you have an automatic transmission.
I think you'll find doing the 30K yourself is easy, it saves you some $$$, and you know exactly what was done.
__________________
______________________________
'08 Lancer ES: daily driver, grocery getter, family tripper
'99 Porsche Boxster: sunny day cruiser, autocrosser, track car, concours winner
'97 Chevy Suburban: horse hauler
'03 Toyota Tacoma: wife's work truck
Offline
Old Nov 7, 2009, 09:59 PM   #101
yep mine is a manual trans also. thanks for the guide. the pics are a great help, im taking my laptop under the car with me
Offline
Old Nov 9, 2009, 12:12 PM   #102
SMP
2009 Mitsubishi Lancer
Drives: 2009 Lancer SE
I was under the impression that you could not change your own oil if you wanted to keep your warranty. How would you prove that the work was done in the event that something happened?
Offline
Old Nov 9, 2009, 12:39 PM   #103
Drives: lancer
i did an oil change today. just make sure you keep the reciepts
Offline
Old Nov 10, 2009, 05:19 PM   #104
DIY voids warranty coverage? I don't think so . . .
Quote:
They may exist, but I'm not aware of any car company that REQUIRES maintenance performed by a dealer to keep warranty coverage. I don't know if there's a law against it, but I've never seen such a requirement.
For grins I just went through the Warranty and Maintenance Manual that came with my 2008 Lancer ES. Unless I missed it, there is no language that comes close to stating a requirement for dealer service (or any exclusion of DIY) to maintain the warranty. The closest thing I saw is language on p. 34 that says, "Your Mitsubishi Motors Dealership is in the best position to provide proper maintenance service . . ." If anything, this is a plea to bring your car to for service. I think there is thus an implication that you might take your car somewhere else or DIY.
On page 9 I see the following: "Receipts covering the performance of maintenance services should be retained in the event questions arise concerning maintenance. These receipts should be transferred to each subsequent owner of this vehicle. MMNA reserves the right to deny warranty coverage if the vehicle has not been properly maintained. However, denial will not be based solely on the absence of maintenance records."
Notice it does NOT say, "Warrantly coverage WILL be UPHELD based solely on the PRESENCE of maintenance records." However, it's a fairly clear implication that if you do your work somewhere other than , you have a reasonable expectation of keeping warranty coverage if you document the service.
There are no guarantees, but the implication is that if you bring a car with a blown engine (etc.) to and expect warranty service, they may try to deny coverage if they can make a case that you did not properly maintain the car. If you have been bringing your car to a dealer religiously for service, and have the records to prove it, then has no leg to stand on in denying your claim. If you have been doing the maintenance yourself, then you should have documentation of this to back your position.
Possible scenario #1: Your motor blows at 50K miles and you bring your car in to have it fixed under warranty. The dealer says it appears that your oil is too old/not the proper grade, and they won't cover you. You have no evidence to support the contention that you have been maintaining your car properly. You're likely screwed.
Possible scenario #2: Your motor blows at 50K miles and you bring your car in to have it fixed under warranty. The dealer says it appears that your oil is too old/not the proper grade, and they won't cover you. You show them your Warranty and Maintenance Manual with receipts stapled in place for each service, dates, boxes checked, etc. I guess some dealers might protest, but I think most will cover you. If the dealer is a dick about it, be aggressive, threaten legal action, communication with MMNA, etc. If you have the documentation, then I think the law is on your side (but I'm not an expert on the law).
Consider this as well, what if you were taking your car to a Jiffy Lube or independent mechanic for regular maintenance. Assuming you kept records, do you expect would honor that? I think they would. Think of how many soccer moms and penis-less men use Jiffy Lube. (Just kidding about that penis-less thing, but I couldn't help it) I don't think or any other car maker is denying them warranty coverage for using Jiffy Lube. Well, how are receipts from Jiffy Lube any better proof of maintenance than receipts for 5W-20 Mobil 1 from Wal-Mart? Does a receipt from Jiffy Lube prove that the tech put in the proper amount and grade of oil? Who is to say the tech didn't drive your car into the service bay, eat his lunch, then pull it back out and hand you the keys?
So, I guess my point there is that I don't think could argue against DIY work any more than they could argue against work done by Jiffy Lube or any other non-mitsu mechanic--assuming records are in order.
I may (note, MAY) bring my car to a dealer for the 60K service. Why??? Well, at that point I may just want another set of eyes taking a look at things. I think I know what I'm doing when I look at CV boots, suspension components, etc., but I'll admit that a trained mechanic might see something that I missed. If I were to have a problem further on down the road (literally), then I would at least have one data point where the dealer gave the car a seal of approval. For example, if I have a problem at 73K the dealer can't say the car has been neglected for 73K miles and it's all my fault. That being said, I don't think I could stand having a dealer charge me hundreds of dollars to install spark plugs, change oil/filter, and replace a couple of air filters. Maybe I would find out what would charge if I did all the installing/replacing myself and just wanted them to do what would basically amount to a safety inspection.
Anyway, I just did the 37,500 maintenance on 10/24/09, and it's all documented on page 38 of my service manual, along with a receipt from Wal-Mart showing $22 for Mobil 1 5W20 and $4.24 for an oil filter. No Jiffy Lube or anyone else will do an oil change with synthetic for $27.82 (tax), and it takes me less time to DIY (even with a tire rotation) than it would for me to drive into a Jiffy Lube and wait for them to do the work.
__________________
Offline
Old Nov 10, 2009, 10:19 PM   #105
Drives: 2006 RA Lancer
^not too sure about american law, but they cant void your warrenty if they dont do the servicing, as long as it actually has been done and documented you will be fine
what they do offer here tho is if you do do all your services with mitsubishi they will extend your warrenty from 3yr/Xkilometers, to 5/10year and extend the kilometeres covered
__________________
Quote:
Originally Posted by Lancer7 View Post
Fake titties are like driving an ES with an Evo body kit. They look good till you put your junk in the trunk and find out they don't go anywhere.
Quote:
Originally Posted by CleverUserName View Post
you'll pull dudes all day in an evo, whether you want to or not.
Offline
Tags
08, 2009, 5w, distance, evo, filter, gts, lancer, mitsubishi, mobil, mobile, oil, size, synthetic, type, wrench
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
