Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 9, 2007, 01:38 AM   #16
Personal Sales Rating: (0)
Drives: lancer 2008
Quote:
Originally Posted by Turbo Dizzle View Post
The dealer gave me a new washer 2 dollars for pice of mind change it dude.
Is this a washer on the drain plug? I didn't notice it had one when I was doing my oil change
Offline
Old Jul 9, 2007, 03:11 PM   #17
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Quote:
Yes, on the drain plug. Chances are that it doesn't matter. I have friends that used the same washer for 100k with no problem. I won't be changing the washer on my Lancer unless it starts leaking oil.
Might be worth checking at the next oil change. If yours is missing, buy one and install it.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Jul 9, 2007, 05:58 PM   #18
Drives: lancer 2008
Yes, it was there, the factory paint fused it together with bolt. I agree with you
that it doesn't require a new one every oil change however new or used, people
should check for leaks when oil pressurizes.
Offline
Old Jul 9, 2007, 07:12 PM   #19
Drives: 2008 lancer
The mitsu oil filters have a damper in them that prevents the oil from back flowing out of engine after turning the vehicle off. This prevents dry start ups. May want to verify that the aftermarket oil filters contain this same type of damper to increase the engine life. The effects won't be seen immediately but will surely be noticed down the road.
Offline
Old Jul 11, 2007, 05:29 PM   #20
lchaidez's Avatar
Drives: 2008 Mitsubishi Lancer GTS | 1986 Mazda RX7 N/A | 1990 Mazda RX7 T2 Coupe
Send a message via AIM to lchaidez
well... in the end I dont see much gain from switching to synthetic just yet. Besides, if you do blow your engine you got nothing to worry about. The warranty should cover it
anything else interesting about oils? What about Neo Synthetic for the tranny? I used Neo synthetic in almost all the cars I've driven. Whether its mine or my moms. Neo has been terrific, and YES you could feel the difference.
K&N filters are also great, but I wouldnt leave any filter for over 3.2k miles or a long trip. Id take my chances and spend a couple bucks... :P
Offline
Old Jul 13, 2007, 08:18 PM   #21
Drives: 2008 lancer
Engines that are designed for different oil really should have the oil they were designed for. Bearing clearances, seals, maintenance schedules, .... etc are all derived around what they need. I wish this question could get an official answer from someone other than my local Mitsu srevicedept. that doesn't seem to really know anything about the car yet. Anyone have a dealer shop manual yet? That might specify the correct oil.
Offline
Old Jul 14, 2007, 07:30 AM   #22
EvoM Moderator
Quote:
I just put in a PM to the member I know that has access to his dealership's FSM. We'll see if he posts up.
__________________
Modern Warfare 2
Offline
Old Jul 14, 2007, 06:56 PM   #23
Personal Sales Rating: (42)
kmxxbadboy's Avatar
From the 2008 Lancer FSM:
Specified Engine Oil: Engine oils displaying ILSAC certification symbol ("Starburst" symobol) or conforming to the API classification SM or higher.
Total quantity: 4.3dm^3 (4.52 quarts)
NOTE: SAE 5W-20 engine oil is strongly recommended for optimum fuel economy and cold starting. SAE 10W-30 may be used when the normal operating temperature is above 30 degrees C (100 degrees F).
Offline
Old Jul 14, 2007, 07:13 PM   #24
gts_in_nj's Avatar
Drives: girls crazy in his 08 GG GTS
Send a message via AIM to gts_in_nj
i wish i knew how to change my own oil...i've been waiting for maywood mitsubishi to get back to me about an oil change and alignment... pretty $hitty service IMO
Offline
Old Jul 14, 2007, 07:26 PM   #25
kmxxbadboy's Avatar
If you want, you can come change it with me at my house. It's definitely not Maywood Mitsubishi... work actually gets done in my garage. LoL.
Offline
Old Jul 14, 2007, 07:27 PM   #26
kmxxbadboy's Avatar
Quote:
What mileage are you at?
Offline
Old Jul 16, 2007, 03:57 PM   #27
EvoM Moderator
No mention of synthetic vs. non-synthetic?
__________________
Modern Warfare 2
Offline
Old Jul 17, 2007, 04:30 AM   #28
GTS08's Avatar
Drives: Lancer GTS 2008
here in Puerto Rico my oil change its for free !!!
Offline
Old Jul 17, 2007, 08:48 PM   #29
Drives: 2008 lancer
with the service interval at 7500 miles I am still thinking synthetic or synthetic blend.
Offline
Old Jul 18, 2007, 11:22 AM   #30
EvoM Moderator
That is a damn good point.
__________________
Modern Warfare 2
Offline
Tags
08, 2009, 5w, distance, evo, filter, gts, lancer, mitsubishi, mobil, mobile, oil, size, synthetic, type, wrench
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
