Ho-To-Program Keyless Remote From Ebay
I got it used so I don't know if it ever had the option. Is there a way of checking? Also, how far up does the "jumper" need to be? I got the paper clip shoved all the way up there and that didn't work
i did this but my remote doesnt work for some reason i guess. the doors locked and unlocked when i pressed the hazard button 6 times then did the remote part of it and it didnt work. what can be wron with my remote? does anybody have a picture of the inside of the remote? i just changed the battery also
So do you need the FCC ID CODE
FcC id code or is that just BS, I called my dealership and said they had to program it and so on because the code on the remote always changes and so on its never the same... I posted on the FCC but no answer until i found this .....I am waiting to buy a remote on ebay but hesitant about the Fcc id on it... would it matter...?
the fcc on the back of your original keys has to match the new remote. Make sure u follow the instructions carefully from www.programyourremote.com (the first Post). and also remember that your doors must be shut before connecting the 1 and 4. I used a 2 paper clips and a wire with 2 alligator clips. so u plug in the two paper clips and get in your car and put the keys in the ignition and then connect the two together and follow the rest of the instructions. It works great and only took a couple minutes!!! Paid 8 dollars on ebay for remote and had a key made at walmart for 1.37. yes walmart makes double sided keys!!!!!!
