Sep 27, 2005, 04:42 PM
Personal Sales Rating: ( 18)
Drives: 2003 Lancer OZ Rally Edition pheonix red
ideas to stop evo7 wing shaking
I have an rrm evo VII ABS wing. It fits great and goes on tightly. its the center cross section that shakes up and down in the wind. I use rubber washers, foam tape, etc and it is adjustable and ive tried all angles. It still shakes up and down. Any ideas to make it more rigid?
Ive thought about either.....
1.wrapping cross section in fiber glass.
2.put a peice of sheet aluminum on the bottom.
3.angle iron on rear/top of cross section and form it to look like a lip. (from rob)
any opinions on these or any other options would be much apprectiated!
__________________
~Maines premier import tuner car club~
Evo-Imports
Offline
Sep 27, 2005, 04:47 PM
Personal Sales Rating: ( 3)
Drives: 2009 Lancer GTS
dont worry about it? lol jk but u could always just take the center part out n lay some more fiberglass on it to make it more structural sound, but i mean if u really wanted to i guess u could do idea #2 n make a bracket for the aluminium that goes under the spoiler to connect to the sides?
Online
Sep 27, 2005, 05:09 PM
the fiberglass idea will make it look, if I do it good, like nothing was done..thats why I like that idea so much. Im thinking of doing mat and doing like 3 coats on underside of wing. may make it like 1/4 inch thicker I think. Think that would make it strong enouph?
__________________
Evo-Imports
Offline
Sep 27, 2005, 11:15 PM
hmm, is ur wing hollow inside? if it is maybe u should cut the underneath part fill it with like spray foam then do the aluminum idea?
Online
Sep 28, 2005, 12:11 AM
Personal Sales Rating: ( 2)
Drives: 04 IS300
take it off?!?!?!
Offline
Sep 28, 2005, 02:36 PM
drill 3 holes, 1 on each corner, 1 in middle. fill it with expanding foam (great stuff).
if that doesnt work wrap it in fiber glass, it would cover the holes and make it stiffer as well.
__________________
Evo-Imports
Offline
Sep 28, 2005, 06:08 PM
Quote:
thats kinda what i meant plus lots ezier lol
Online
Sep 29, 2005, 03:36 PM
yah, im gonna try that for sure, ill post how it goes. mabey do a how to so someone else with my problem knows what to do.
__________________
Evo-Imports
Offline
Sep 29, 2005, 04:43 PM
ya keep us posted
Online
Sep 30, 2005, 07:12 AM
Personal Sales Rating: ( 16)
Drives: '05 Elanta GT
put some clear, low temp, silicon in each slot to take away from the area it has to move.  thats a typical polish idea for me but my spoiler was loose and i fixed it that way...plus the stuff peels right off if you want to get rid of it. you got nothing to lose.
__________________
...fill your hands with something tangible...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
