Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Forums > Lancer General
Sign in using an external account
Register Forgot Password?
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Mar 25, 2010, 08:00 PM   #1
Personal Sales Rating: (2)
Garage is empty, add now
Braydo25's Avatar
Drives: '90 240sx / 2005 Evo IX Mr (Weekend Car)
Points: 3,059, Level: 34
Points: 3,059, Level: 34 Points: 3,059, Level: 34 Points: 3,059, Level: 34
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
4g94 Exhaust Manifold Bolts Torque?
Hey, I wasn't able to find this on the forum, so I'm hoping someone could answer my question or direct me to an answer.
I need to know what the torque specifications are for the bolts holding the exhaust manifold to the head of the 4g94 motor?
Thanks in advance.
Offline
Old Mar 30, 2010, 12:34 PM   #2
Personal Sales Rating: (8)
blaze_125's Avatar
Drives: Yellow OZ
Points: 12,527, Level: 73
Points: 12,527, Level: 73 Points: 12,527, Level: 73 Points: 12,527, Level: 73
Daily Activity: 1.1%
Daily Activity: 1.1% Daily Activity: 1.1% Daily Activity: 1.1%
see attachement
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Apr 2, 2010, 10:07 PM   #3
Personal Sales Rating: (0)
vityenyka05's Avatar
Drives: LANCER 4G94T
Points: 1,977, Level: 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Send a message via AIM to vityenyka05 Send a message via MSN to vityenyka05
Anyone knows the head stud torque for a 4g94 02 mitsubishi lancer oz??
__________________
I HAVE A TURBO SETUP FOR SALE, IF ANYONE IS INTERESTED, YOU'LL NEED TO BUY MORE PART TO FINISH IT, BUT I WENT A DIFF ROUTE, BECAUSE I GOT A CRAZY GOOD DEAL ON A BIG 16G TURBO SETUP FOR MY LANCER..
BASICALLY WHAT I HAVE IS A CAST IRON T28/T28 MANIFOLD, CHROME HEAT SHIELD, GARRETT T25 TURBO, AND A FULL CUSTOM DOWNPIPE WITH A FLEX PIPE, STRAIGHT TO UR CATBACK EXHAUST.. THERE ARE BUNS WELDED ON TO IT FOR YOUR O2 SENSORS, PLUS EXTRA ONE FOR YOUR WIDEBAND. PM ME FOR MORE DETAILS.
Offline
Old Apr 5, 2010, 11:26 AM   #4
Mikylek's Avatar
Drives: 97 Talon TSI AWD 6 Bolt Swap.
Points: 1,312, Level: 20
Points: 1,312, Level: 20 Points: 1,312, Level: 20 Points: 1,312, Level: 20
Daily Activity: 0%
55 ft lbs I believe. But you must follow the correct bolt pattern then lossen all the way in the opposite order then tighten to 22 lbs. Then make a mark on each then tighten 90 degrees then make another mark then tighten another 90. I'm not 100 percent for sure ill look on alldata when I get home then let you know for sure
__________________
full 6 bolt swap
act 2100
ARP head studs
Counterbalance shaft deletes(both of them)
ported head
some off brand header
hard intercooler piping
3000gt throttle body
big 16g @18 psi
apexi safc II
wally 255
megan test pipe
apexi catback exhaust
NGK bpr7es @ .25
evo III o2 housing
AEM uego wideband
Sinapse Synchronic resirculated
  • If you want it fast and good it won't be cheap
  • If you want it cheap and good it won't be fast
  • If you want it fast and cheap it won't be good
Offline
Old Apr 6, 2010, 04:45 AM   #5
Daily Activity: 0%
k thanks man
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2003, 4g94, bolts, exhaust, forum, hard, head, lancer, manifold, mitsubishi, oem, specs, stud, tightening, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
