Oct 23, 2009, 06:51 PM
Personal Sales Rating: ( 24)
Drives: 03 RR Evo VIII 1/2
Help rewiring Lancer ES to work EVO headlights
 Ok just like the title says. I need to no if anyone rewired their Lancer ES to fit Evo headlights. NON HID Evo lights....
__________________
Rebuilding another 2003 rr VIII
OLD:2006 White RS IX Stock.
Old: 2003 SILVER EVO VIII MODS:BUSCHUR 2.3 stroker, Exedy Twin Disk, DNP O2 HOUSING. TURBO XS DOWN PIPE, CAT DELETE PIPE, TURBO XS CAT BACK, WALLBRO FUEL PUMP, HALLMAN MBC, BOOST GAGE, Buschur Intercooler and upper/lower IC pipe 272/272HKS Cams & cam gears, Buschur intake w/ K&N filter, 750 cc Injectors, Buschur 20g 9 turbo.
365 whp and 375 ft lbs of torque. C16
11.3 @ 119mph
Best 60' 1.656
Offline
Oct 25, 2009, 05:47 PM
I got it wired today
__________________
11.3 @ 119mph
Best 60' 1.656
Offline
Oct 27, 2009, 10:00 PM
Personal Sales Rating: ( 13)
Drives: RWD EVO & 09 Lancer GTS
what did you do?
Offline
Oct 27, 2009, 11:19 PM
Personal Sales Rating: ( 1)
Drives: 2003 Lancer OZ Rally [ Lightning Yellow ]
evo headlights wont fit base lancers w/o the front wide body fenders, oem hood and bumper
that and it will look fugly w/o the evo rear quarters weldedon the es to complete wide body look
Offline
Oct 27, 2009, 11:20 PM
are u talking about cedias ? that are dual beam
Offline
Oct 28, 2009, 01:35 PM
Quote:
Originally Posted by turbotime
what did you do?
First you have to take the wiring harness off the evo light ...... the marker light fits right in perfect no cutting required.... the turn signal I cut the end off of the evo harness and from the engine bay harness. I then soldered the evo plug to the plug that came out of the engine bay….. works great......Now the high and low beam......on the evo light you have two lights bulbs on the lancer their is only one light bulb with 3 wires, the black is the ground and one is low beam the other is high beam......they both can share the same ground..... I then cut the headlight plug at the engine bay ……cut off the low beam plug from the evo harness……I then used the same plug from a dodge for the high beam and soldered them up. They work great …make sure you use extra wire for the low beam…wont reach cause the are separated…I forgot to note what color wire is low and high beam so just temporary hook up the low and high and test it out.
__________________
11.3 @ 119mph
Best 60' 1.656
Offline
Oct 28, 2009, 01:38 PM
The car has the complete evo front end and rear doors.....it goes to the shop the second week in Nov. to get the rear quarters done.
__________________
11.3 @ 119mph
Best 60' 1.656
Offline
Oct 28, 2009, 04:00 PM
Personal Sales Rating: ( 3)
Drives: RX-7 convertible, 92 Accord...... R.I.P. Lancer
Wow, what a complete waste of money.
__________________
Quote:
Originally Posted by CaliMR
They found a lost book, the book of Raptor Jesus. The dinosaurs spent so much time on the internet that they did not even notice the comet approaching the earth until too late, and Raptor Jesus sacrificed himself to protect the dinosaurs from the comet. Then he arose on Easter and guided all the faithful dinosaurs to the moon which is where they live now. All those that did not believe were left on earth and died when Moses caused the floods.
Offline
Oct 28, 2009, 04:13 PM
Quote:
Wow what a wast of a post.....I have an Evo and a WRX...hell I had afew Evo's So I want to play with a lancer and some parts that I have..........
__________________
11.3 @ 119mph
Best 60' 1.656
Offline
Oct 31, 2009, 10:38 PM
Quote:
oh cool.. post pics when u are done i wanna see
Offline
Oct 31, 2009, 10:40 PM
^ waste of a post and a troll
if all u have is hate then stay the heck out of the lancer forums. we dont need that here
Offline
Tags
03, 16, 2009, 20g, es, evo, fenders, fit, headlight, headlights, lancer, oem, oz, whp, widebody, wrx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
