Sep 5, 2009, 01:19 PM
Personal Sales Rating: ( 0)
Drives: 08 GTS / Next up gtr r33
Nitrous in a lancer
givin my addiction to drag racing after hitting the track this year , im curious to see how fast i can get my lancer going down the track staying na , not adding boost , which brings my question is a 50-75 shot of nitrous safe to do in the na 4b11 thats in the lancer? this is a serious question so people that wana be dumb about it save your posts i dont wana hear it , i just want to hear from people that have good info regarding this topic
__________________
TORONTO TUNER SYNDICATE
Founder - President
http://syndicated.forumotion.com/
Toronto Lancer Club - East
Don't drink and drive , smoke and fly
Offline
Sep 5, 2009, 10:41 PM
Drives: 2008 Lancer ES
if you take the engine, rebuild it, so it's structurally capable of supporting the pressure that will cause, it should be able to handle it, but because of the way it's bored out, it'd blow under the pressure.
Offline
Sep 6, 2009, 09:54 AM
whats the smallest shot you can get , is it 50 or 25?
__________________
Founder - President
Offline
Sep 7, 2009, 12:15 AM
25 shot is the smallest shot
Offline
Sep 7, 2009, 06:21 AM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
Quote:
This, and if you're going to spend all the money rebuilding it, you might as well go turbo and have the power on tap all the time, for free (ie. no refilling a bottle).
Offline
Sep 7, 2009, 07:47 AM
Personal Sales Rating: ( 8)
2002 Volkswagen Jetta My Garage
Drives: Evo IX RS JDM
You can use a wet system with 50hp jets without problems.
I recommended a Zex kit.
__________________
EVO IX JDM RS - Jestr Reflash - FP Red Turbo, ported by FP, 3" Perrin downpipe, test pipe and magnaflow exhaust, Invidia O2 housing, walbro pump, HKS 272 exh. and int. cams, OBX fuel rail, PTE 1000cc injectors, APR head bolts, ACT Xtreme clutch kit XTSS, Injen intake and intercooler pipe, 3" ETS Intercooler, custom LICP, XS Power exh. manifold, Ported int. manifold, 65mm throttle body, Forge BOV, Crank pulley, Greddy Proffec B EBC, Zex Nitrous Kit, Zex window switch and Hotchkins springs.
Offline
Sep 7, 2009, 09:46 AM
Quote:
thats true nd as badly as i want turbo im gonna stay na with the lancer , the next ride is gonna be boosted from the start either a skyline or evo 8 or 9 , but for now i wana see what i can get out of the na lancer , not expecting much to be honest
__________________
Founder - President
Offline
Sep 7, 2009, 09:47 AM
see thats what im thinking , if i ran a kit with say a 25-35 shot , that really isnt much , and i would think the engine can handle a small shot , but then again i dont know much about the 4b11
if it was the 4b11t then from what i understand it can take a 100-150 shot no problem
__________________
Founder - President
Offline
Sep 7, 2009, 03:46 PM
Personal Sales Rating: ( 4)
Drives: 97 GSX, 03 Cobra, 97 Supra 99 Suburban, 91 Blazer, 98 Bourget, and Harley Softail and more toys
Say good by warranty when it blows
Offline
Sep 7, 2009, 05:49 PM
Personal Sales Rating: ( 13)
Drives: RWD EVO & 09 Lancer GTS
I was doing some reading today on the 4b11. Mainly comparing the 2.4 to the boosted 2.4 in the caliber srt4. I found they are exactly the same block and crank but the bore is different as is the pistons and rods. What I'm saying is basically our blocks should be able to handle the power as so can our crank, however its the little things that will kill you like the differences in tolerances, lower end rings, forged vs. non forged pistons and rods ect.
I would assume this to be the same for the evo x engines. You could probably run a 25 shot or 50 shot, but I can see any one of the above mentioned failing rather quickly.
At least with boost you have a bit more control and you have more gauges to monitor whats going on and such...
I'm surprised you had a change in heart, staying n/a after all...
not sure what your budget is like since I know you just got that new place but $200 a month could net possible boosting by march
Offline
Sep 7, 2009, 05:50 PM
Quote:
as sad as it would be im not concerned about warranty , i wouldnt even think of nitrous or boost on it till i have a backup car tho , just looking into it for now
__________________
Founder - President
Offline
Oct 6, 2009, 08:42 PM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer
Drives: 2003 Mitsubishi Lancer OZ Rally Edition
Never put nitrious on a car unless you want to rebuild the engine alot. Turbot it and rebuild the engine once. It will be as fast or faster than an evo
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
