Homemade Short Shifter?
Bomb Squad Unit #02
The distance from the pivot point to the shift linkage is pretty much set, dictated by a large (about 9"x6") nylon enclosure that bolts shut with a hinge and 4 10mm bolts. So if you're just designing a piece of metal for this thing, you're limited to what is ABOVE the pivot point, while the part below is pretty much fixed. Sorry.
Bomb Squad Unit #02
Well, even if it was curved the distance between the two points remains the same. Curves with 1 pivot point act as it they are straight. HOWEVER, I am sure the curves on the part ABOVE the pivot can affect the shifting in some way. Not sure how, though.
But believe me, I looked into all of these possibilities when trying to justify buying an aluminum stick for $150, and found out it just isn't as complicated as people make it out to be.
well its okay i bought mine, underhood and base bushings for 99$, even if it is just a shorter stick...
o yeah there are 2 b&ms by the way... one requires you to cut into your housing i hope that one does something a lil more then just change the top part
Bomb Squad Unit #02
Yeah, I think that one does more, which probably does alter the pivot point because it alters the housing. But your $90 "stick" is still a good choice because it is angled and weighted to feel correct. Not sure how much the ebay sticks researched on that. if it's not weighted right, expect a lot of missed shifts. Which, btw, is a good reason to use the knob it came with if applicable.
As you can see on the image, with a longer bottom part the linkage travels further.
If you look at this link... you'll see that should be the **** you're looking for. B&M gets you to cut part of the assy since the lower arm is longer and needs clearance.
https://www.evolutionm.net/features/...mfeatures/42/2
Terror Rising
Jul 28, 2019 06:20 PM
freshpl
61
Dec 4, 2009 09:01 AM
SHhhhh
Jul 11, 2008 02:34 PM
