evolutionm.net
evolutionm.net (http://forums.evolutionm.net/)
-   Lancer Engine Tech (http://forums.evolutionm.net/lancer-engine-tech-56/)
-   -   For those looking into Pulley Kits (http://forums.evolutionm.net/lancer-engine-tech/14432-those-looking-into-pulley-kits.html)
mobius97 Feb 20, 2003 01:08 PM
I have seen some people on here looking for pulley kits. This might be something you might want to call on and check out to see if they will REALLY work on the lancer. Just go to overboost.com and select engine parts and select mitsu/lancer under pulleys and it pops up some for the lancer that isslenger makes. Might be worth some ivestigating guys. just an FYI.
customlancer Feb 20, 2003 01:43 PM
thats cool with me i am going to check it our. I have been looking for pulleys. thanks
pjal84 Feb 20, 2003 04:16 PM
Just as an FYI, the only person who successfully mounted an underdrive pulley on his car just found himself taking it off since the belt kept slipping. It's really quite a shame that Unorthodox (who makes the damn things for the 4G93) won't bother to look into offering it for the 4G94.
LaNceRiTiZ Feb 20, 2003 04:26 PM
....did they confirm that w/ you or anyone here on forum..
that they are not making em for the Lancer?....
pjal84 Feb 20, 2003 04:32 PM
Well the fact that I've emailed them repeatedly about asking them to just grab a Lancer and a pulley they already make and just see if it'll have a snowball's chance in hell to fit, and they don't get back to me, I'd say yes, they're not terribly interested. They will offer up a custom set for some $ though. This has all already been expressed on the forum already.
Gen4Racing Feb 21, 2003 08:04 AM
the mitsubishi part number for the lancer crank pully(damper) is
md373417 which is the same part number used on the 1.8L mirage 2 and 4 door. same part number, same part
qaz003 Feb 21, 2003 08:19 AM
is it even worth getting. whats the point in an aftermarket pulley system
KMcW Feb 21, 2003 08:52 AM
Pulleys make less work for accessories therefore making more power for your engine at the ckrankshaft.
BTW- I was the one who had to take the pulley off, what a waiste of time and it for the Lancer specifically. Doesn't inspire much hope with me.
qaz003 Feb 21, 2003 09:00 AM
ummm checked the sight. nothing for the lancer at all checked all the categories.
mobius97 Feb 21, 2003 10:26 AM
Quote:
Ummm check a little harder. Just select egine componets and choose make model...thats all thats too it man. Just checked again and it's there!!!
http://www.overboost.com/obs/browse_...&model_id=242. but as I was saying you need to call them to make sure it is the right application. Dont always trust what they say on the site.....I once ordered some headers for an altima and becuase they said they worked and recieved som edlebrocks for a rwd car....
pjal84 Feb 21, 2003 03:03 PM
You just made my day if that's legit. If you were able to nab the pulley number, could you grab the belt number as well, just as a double check of sorts?
Gen4Racing Feb 22, 2003 09:39 AM
its lagit.... i work for a dealer in IL... trust me
Gen4Racing Feb 22, 2003 09:40 AM
belts will not be the same only because of diff lengths
KMcW Feb 23, 2003 01:37 AM
Which pulley are we talking about here?
Gen4Racing Feb 24, 2003 11:51 AM
crank pully
also known as harmonic damper
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
