Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jul 7, 2012, 11:34 PM   #1
Personal Sales Rating: (2)
My Garage
Live4Redline's Avatar
Drives: 06 IX GSR / 03 VIII GSR / 03 OZ-Rally
Info Request: 4G93 and 4G94 Heads
So its old news that the heads swap between the 4G93 and 4G94 motors but what's the differences? I know the cam between the Mirage 4G93 and Lancer 4G94 heads are different and the mirage cam is considered a small upgrade. But as for the head its self, anything to note?
Also as for the mirage cam being swapped into a Lancer. I've read a post that said it works but a friend and I gave it a try with his Lancer 4G94 and the cam angle reluctor did not directly swap over. It would need to be modified to fit properly and he decided not to complete the swap. Has anyone else did the grinding to make this work in a 4G94?
__________________
Daily: 2003 Lancer ES & 2005 Montero Limited
AutoX: 2006 Lancer Evolution IX GSR - Classed in ASP & NXA [#114]
Project: 2003 Lancer Evolution VIII GSR - *Worlds First G4JS Powered Evo*
Future: 2014 Mirage DS - Cause Race Car!
VMSC //// NASA Mid-Atlantic //// SCCA-BRR
- Virginia AutoX State Championship : ASP Class Winner 2013
Offline
Old Jul 8, 2012, 12:20 AM   #2
Personal Sales Rating: (0)
Garage is empty, add now
jujukiller's Avatar
Drives: 2002 Mitsubishi Lancer OZ rally
ATACO222
4g93 camshaft on 4g94 motor, tune?
__________________
"simplify and add lightness"
- Colin Chapman
My car doesn't have "body damage" it has battle scars.
Offline
Old Jul 8, 2012, 11:23 AM   #3
Personal Sales Rating: (13)
2005 Mitsubishi Lancer
slatermvp's Avatar
Drives: 2005 Lancer Es
I think the 4g93 head flows better because it was meant for a 1.8, thus compensating for any power loss due to its displacement. I would suggest swapping the intake manifold as well.
__________________
install is done!!!!!!!!!!
tuning stage now.
suspension next.
Offline
Old Jul 8, 2012, 06:36 PM   #4
Personal Sales Rating: (44)
MurphDurph's Avatar
Drives: 02 OZ-T :)
Send a message via AIM to MurphDurph Send a message via Yahoo to MurphDurph
Quote:
youre supposed to swap the one on the g94 cam onto the g93 cam
__________________
vrrrrPSSSHHHvrrrr
xbox live :XMurphDurphX
ADD ME!! :D
Quote:
Originally Posted by lancer2show View Post
never trust $#!t colored trucks.
Offline
Old Jul 8, 2012, 08:52 PM   #5
My Garage
Quote:
Are the ports larger or something or are we just guessing? Also does the intakr manifold swap or do you have to use the 93 head to use the 93 manifold?
Quote:
That sounds all good, but from someone who has messed with this, the reluctor does not just swap. There are alignment pegs on it that do not match with the cam. You can grind them off and it should then fit but I was just wandering if anyone else has done the grinding to make it work.
__________________
Offline
Old Jul 9, 2012, 10:39 AM   #6
MurphDurph's Avatar
Drives: 02 OZ-T :)
i have messed with this and currently running the g93 cam on my lancer...the reluctor swapped over with no issue and it fired right up
__________________
vrrrrPSSSHHHvrrrr
ADD ME!! :D
Offline
Old Jul 19, 2012, 08:22 AM   #7
Lil red '03's Avatar
Drives: not a damn thing
Send a message via Yahoo to Lil red '03
subscribed
Offline
Old Jul 19, 2012, 11:05 AM   #8
Personal Sales Rating: (3)
*02Lancer*'s Avatar
Drives: 02 lancer oz, 09 lancer es 74/76/79 Corvettes, 91 240sx, 83 CJ-7
The heads are the same, The intake manifold from the 4g93 has shorter runners so you will pick up more at the top end but lose a little low end tq. The cam in the 93 has the same lift duration as the stage 1 but i cant remember the company. The intake manifold is a decent mod for price and effort.
Offline
Old Jul 22, 2012, 02:42 PM   #9
slatermvp's Avatar
I think it was the RRM stage one camshaft that resembled the mirage cam.
__________________
tuning stage now.
suspension next.
Offline
Old Jul 22, 2012, 09:54 PM   #10
Personal Sales Rating: (4)
corndog17's Avatar
Drives: 02 lancer
Does anyone know what to adjust in our roms to correct the erratic idle experienced with RRM's stage one cam? CEL for HIGH IDLE is constantly being thrown and the rpm's will go up and down. Until BISS screw is adjusted on throttle body, tach will then rest at 700 rpm. Problem repeats its self the CEL will come on then erratic idle will occur. Help, I dont want to have to put the stock cam bak in. Thanks
Offline
Old Jul 29, 2012, 10:31 AM   #11
corndog17's Avatar
Drives: 02 lancer
bump
Offline
Old Jul 29, 2012, 05:20 PM   #12
My Garage
Quote:
So the heads are the same then? That includes the exhaust and intake manifold flanges? So one can simply bolt the 93 intake manifold to there 94 head with no issues right?
Quote:
Not sure what to tell you... what cell is it throwing? You have a few options for changing rpm levels and idle control but not sure which one is triggering your issue. I've never had the chance to mess with the RRM cam. Any other info you can add in? Only during hot or cold running or anything else to go on?
Offline
Old Jul 29, 2012, 07:15 PM   #13
corndog17's Avatar
Drives: 02 lancer
On cold starting...oh turning on the air conditioner makes the idle go back down to normal level around 650 rpm.
Offline
Old Aug 3, 2012, 09:43 AM   #14
My Garage
Double post, deleted.
Offline
Old Aug 3, 2012, 09:43 AM   #15
My Garage
Review this link and if you still have an issue ill see if i can post up the ecu correction when i get home tonight.
http://www.2carpros.com/articles/engine-idles-too-high
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
