4g63 swap with automatic trans
Is this a possible swap on a 2005 oz rally lancer if so what tran
would I need and what else who's I need I'm a family man that like to push it some times my girl is the reason for me to be asking this she can't drive standered so I have the money I just would like to see some feed back on if there a way I have a 4g94 I wanted to turbo it but a friend of mines did it to his and some how I can steel take him non boosted I was just going to swap my single for a dohc but
any 4 speed auto from a 04-06 lancer ralliart, 4g eclipse, or 9g gallant that is 4g69 powered should bolt up to a 4g63...starter mounting location might be an issue, but you'll have to find out...this isn't something that's done everyday...I'm not completely sure if a 4g63 block has the mounting points for it ( I can't recall if the starter bolts pass through an ear on the block or not, been a while since I changed mine, or even looked at it). The starter on the Evo is mounted basically level with the oil pan if I remember correctly...on a 4g69 the starter is up on the side of the block, which may interfere with the turbo, this and the clutch control system is the main issue when turbocharging a 4g69 engine...
the airtrek might be the only way to go, if the auto was available with the 2.0L turbo.
