Straight Pipe Exhaust....
Old Jul 3, 2011, 11:31 PM
dspucches's Avatar
Is it possible for the exhaust to come all the way back and then cant out like an evo instead of having to go over the control arm??
Old Jul 4, 2011, 09:06 AM
03lances's Avatar
Any particular reason? I have full 3" TBE and am lowered and have mine going over the control arm with no issues.
Old Jul 4, 2011, 12:13 PM
dspucches's Avatar
better air flow...
Old Jul 4, 2011, 12:14 PM
dspucches's Avatar
better airflow maybe??? ment to say it as a question
Old Jul 4, 2011, 12:47 PM
blaze_125's Avatar
What's it gonna give you? 0.0000005hp?
I think you probably heard someone talk about straight exhaust system over the weekend and then you figured something like "hey, straight pipe, that must be the shiznit!". It ain't. Your exhaust system is fine the way it is.
When that bend becomes a bottleneck, make sure you post some numbers on here.
no offense intended.
Old Jul 4, 2011, 06:48 PM
03lances's Avatar
Although im not as blunt as Blaze lol he is right. I have my exhaust following the stock route and I am turbo'ed running the same hp as a stock evo. I have plenty of flow that bend isnt going to restrict anything you can put through it. By the time that is causing a restriction to your flow that will be the least of your problems
Old Jul 4, 2011, 07:34 PM
dspucches's Avatar
haha fair enough... though id ask
Old Jul 4, 2011, 07:35 PM
dspucches's Avatar
non taken blaze btw...
Old Jul 5, 2011, 12:16 AM
steven121's Avatar
dude you wont be making 500+hp where airflow will make all the difference. just run an exhaust a straight pipe will be too loud and it gets annoying really quick.
if you really want to run a straight pipe bolt it up to the car and cut it near the center of the chassis, or have it com out the back and cut off the muffler
Old Jul 5, 2011, 11:04 AM
blaze_125's Avatar
Good My "sens of humor" doesn't always travel all that well over the internet
fugiwara
Jun 9, 2016 10:29 PM
RedEvoxGSR
Oct 22, 2013 07:17 AM
Ralliartize It
Jul 16, 2013 03:28 AM
ryanholder24
13
Jan 29, 2012 06:17 PM
sidtheretard
Aug 26, 2008 08:05 PM
Quick Reply: Straight Pipe Exhaust....
