Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 18, 2009, 09:59 PM   #1
Personal Sales Rating: (0)
Drives: Lancer GTS
What are the chances of getting stronger internals for the lancer?
what do you guys think about a company hopping on the banwagon to make better internals for the lancer? i dont know if thats RRMs thing or not..but if some company actually did make some. what type of gains could you see from that? (like whp numbers) i know obviously evo internals wont do any good
Offline
Old Sep 18, 2009, 10:48 PM   #2
Personal Sales Rating: (6)
2008 Mitsubishi Lancer
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
evo xs are also 86 x 86 mm....evo internals will fit
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Old Sep 18, 2009, 10:51 PM   #3
Drives: Lancer GTS
yeah but wont do any good to NA guys or even turbo guys really..unless your trying to blow your engine.. im talking about internals that would benefit the NA guys to get a lot more power.
Offline
Old Sep 18, 2009, 11:17 PM   #4
yitzac1990's Avatar
like 10.5 or 11:1 pistons? idk, but how would Evo X pistons blow a turboed Lancer motor?
__________________
240 whp
228 wtq
Offline
Old Sep 18, 2009, 11:41 PM   #5
Drives: Lancer GTS
compression on evo are made for way higher boost than the 5-7lbs that the lancers are running..in order to get a benefit out of those aftermarket/stock internals you would have to up the boost more
Offline
Old Sep 18, 2009, 11:48 PM   #6
yitzac1990's Avatar
the only reason someone would want stronger internals for a turbo application is to turn up the boost anyways....
__________________
240 whp
228 wtq
Offline
Old Sep 19, 2009, 12:14 AM   #7
Drives: Lancer GTS
exactly thats why im trying to find out of someone will make internals for the NA with lower compression so these can get bigger gains. im not familiar with n/a 4 bangers so im not sure what type of gains you could expect if someone did..thats what im trying to figure out
Offline
Old Sep 19, 2009, 12:17 AM   #8
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
Ok if you are going to get pistons for NA you either keep the same compression or go higher. Going lower would rob power from the engine.
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Sep 19, 2009, 12:37 AM   #9
Drives: Lancer GTS
by lower i meant lower than Evo
Offline
Old Sep 21, 2009, 03:47 AM   #10
Drives: 2009 Mitsubishi Lancer GTS
Why would you want lower compression pistons than the evo on a n/a application. With n/a you want to go higher ratio to see gains in hp... But I would love to see some 2.4 heads, pistons, forged crank and rods, cams, larger throttle, and an aluminum intake with a broader rpm range o.o
__________________
[ ] TenzoR Sport Type-M Machined 18"
[ ] 1-1.5" Lowering Springs or Coilovers
[ ] RalliArt Taillamps
[ ] Projector w/HID Headlamps
[ ] RalliArt Rear Bumper
[ ] Header
[ ] High-Flow Cat
[ ] RalliArt Dual Catback
[ ] SRI w/ RalliArt Intake Scoop
[ ] RRM CVT Piggyback ECU
[ ] RRM Timing Control Box
[ ] Performance Crank Pulley
[ ] RRM CVT Trans. Cooler
Offline
Old Sep 21, 2009, 11:32 AM   #11
Personal Sales Rating: (13)
turbotime's Avatar
Drives: RWD EVO & 09 Lancer GTS
If you staying n/a, there is a stroker kit offered up to 2.5L
Our 2.4's have a 10:5:1 compression so really unless you want to get into some serious engine work, ie. boring, oversize customs pistions and rods then your not going to really see any gains worth your while. By the time you spend that money you may as well be turbo'd
If your going turbo and want to put around 300-400hp I'd just run the 2.4 caliber srt4 pistons and rods. Pretty inexpensive upgrade as the rods,piston, and rings might run you $380 max for a set of four. crank we dont need to replace unless your planning on over 550hp
I'd probably run an aftermarket headgasket of some kind and maybe arp headstuds if I was pushing closer to 400hp or more but other then that you should be ok.
Offline
Old Sep 21, 2009, 01:41 PM   #12
yitzac1990's Avatar
Quote:
lol wouldn't we all!!!!
__________________
240 whp
228 wtq
Offline
Old Sep 23, 2009, 06:30 AM   #13
So the parts from the SRT Cal will fit? I know they kinda have the same block except for the exhaust ports. Would R/T or SRT heads and intake fit as well?
__________________
[ ] Header
[ ] High-Flow Cat
Offline
Old Sep 23, 2009, 07:05 AM   #14
yitzac1990's Avatar
wow! hey not to bash you or anything, but where did you find your info? I have nothing to say against it, just wondering if this is all true, because I eventually want to get 300 whp
__________________
240 whp
228 wtq
Offline
Old Sep 23, 2009, 07:12 AM   #15
i spoke with the brian crower crew about this, they are in the works on some 2.4L internals.
hopefully by next summer we might actually have stuff for the 4b12
Offline
Tags
08, 2003, 2008, 4b11, 4b12, caliber, engine, es, gts, header, internals, kit, lancer, mitsubishi, ralliart, rebuild
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
