Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 18, 2009, 03:09 AM   #1
Personal Sales Rating: (0)
Drives: 2009 Mitsubishi Lancer GTS
Hi flow cat and factory warranty issues
I'm hoping to put together a full exhaust to buy and wanted to know if anyone had issues with high flow cat? Would high flow cats void the warranty iff I took it in to be serviced?
__________________
[ ] TenzoR Sport Type-M Machined 18"
[ ] 1-1.5" Lowering Springs or Coilovers
[ ] RalliArt Taillamps
[ ] Projector w/HID Headlamps
[ ] RalliArt Rear Bumper
[ ] Header
[ ] High-Flow Cat
[ ] RalliArt Dual Catback
[ ] SRI w/ RalliArt Intake Scoop
[ ] RRM CVT Piggyback ECU
[ ] RRM Timing Control Box
[ ] Performance Crank Pulley
[ ] RRM CVT Trans. Cooler
Offline
Old Sep 18, 2009, 03:16 AM   #2
DJ Christian's Avatar
Drives: 2009 Graphite Gray Lancer GTS
Yes.
Offline
Old Sep 18, 2009, 04:03 AM   #3
So even though it wouldnt directly affect the engine in a bad way it would still void the warranty?
Would headers and a catback with the original cat void the warranty as well?
what about the rrm piggyback ecu and timing module?
__________________
[ ] Header
[ ] High-Flow Cat
Offline
Old Sep 20, 2009, 11:10 AM   #4
Personal Sales Rating: (1)
cRc`22's Avatar
Drives: WW 08 GTS
Send a message via AIM to cRc`22
unless ur car malfunctions and u tell them to fix something that they can prove the aftermarket product broke ur warranty is fine.. ive had my car for almost 3 yrs and ive never been to the dealership.. why do ppl go so often?
__________________
--Injen Cold Air Intake
--WORKs Drop-In
--Injen SES Exhaust
--WORKS TUNED
--WORKs Rear AntiSway Bar
--HAWK HPS Front Pads
--WORKs 4 Corner SS Brake Lines
--MeganRacing Coilovers
--Enkei RPF1 18x8+35
ForSale :: Stock 08-09 GTS RearSwayBar. upgrade for 08-09 DE/ES models http://forums.evolutionm.net/sale-wh...-bar-20mm.html
Offline
Old Sep 20, 2009, 01:35 PM   #5
Personal Sales Rating: (6)
2008 Mitsubishi Lancer
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
knowing , they will most likely void ur warranty for not washing your car on a regular basis. if you have a cool dealership where the people are chill, nothing should void your warranty, unless something goes wrong, and the dealer can prove one of your mods caused it. either way though, usually any new exhaust from the cat back WONT void your warranty, because from the cat back is just noise, the cat itself takes care of the emissions thing....however, replacing the stock cat will void your warranty.
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Old Sep 20, 2009, 11:55 PM   #6
JHizzle's Avatar
Drives: Evo X GSR,08 GTS (for sale), and a K20 again.
^ true as said above, but when you mess with the Cat, you give them a lot more ways to try to blame it on the aftermarket cat. so replacing the cat wont directly void your warranty. just like a turbo dosent void your warranty..but you bet your ass if something happens they'll find a way to blame that due to the turbo and what not.
as far as the issues you'll have with the car i cant see too many problems coming from changing the Cat, they cant blame any tranny problems or major things like that..so its all about what you wanna do
also remember when a dealer "voids" your warranty they dont void everything entirely its either your power train warranty, suspension something like that..you can have a turbo on your car and have a problem with your window and they cant refuse to fix your window because you have a aftermarket turbo.
Offline
Old Sep 21, 2009, 12:08 AM   #7
Personal Sales Rating: (52)
mantosride's Avatar
Drives: 2006 evo mr
mitsu can be very tuff, depends on who the warranty rep in your area !
Offline
Old Sep 21, 2009, 03:35 AM   #8
Well I figure ill just keep my exhaust in case there is ever an issue. Ill ask whenever I can remember to call my dealer. I'm sorry if this is a dumb question but do they make long tube headers for 4 cyl. And would our lancers ever see one if so?
And tis there only one set of header out for the 2.4?
__________________
[ ] Header
[ ] High-Flow Cat
Offline
Tags
09, 2008, 2009, back, cat, cats, es, flow, gts, high, lancer, mitsubishi, void, voids, warranties, warranty
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
