Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 11, 2009, 04:11 PM   #1
Personal Sales Rating: (3)
Ozdriver's Avatar
Drives: 2003 lancer oz
Send a message via AIM to Ozdriver
idle issue
this has been going on for quite some time. I was hoping that someone here may be able to point me in the right direction. my oz is idling very low and it bounces from approx 700 down to 400rpms while sitting at lights or in traffic. it makes a bit of a clicking sound when the idle gets to the lowest point before coming back up this sound seems to be coming from somewhere around the throttle body . other than this idle problem the car runs great it doesn't bog down or anything no CEL or anything like that. I have checked for vacuum leaks and have not found anything. if you guys could point me in the right direction I would greatly appreciate it
__________________
http://www.cardomain.com/ride/2318796
http://www.myspace.com/crit_wilson
speed kills live forever drive a honda
YOU"VE GOTTA PAY TO PLAY
this is what I have so far:
aem intake
RRM intake manifold
RRM throttle body
RRM high flow fuel rail
RRM header
greddy evo 2 exhaust
magnacor plugwires
light weight underdrive pully
SAFC2
tein stech springs
RMR strut braces front and rear upper and lower
Offline
Old Sep 11, 2009, 06:59 PM   #2
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
I suggest getting 2 things, first is MAF cleaner its an aerosol can even walmart sells it, and second air intake and throttle body cleaner I would start there my car did the same exact thing and just those 2 things fixed it right up
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Sep 11, 2009, 07:52 PM   #3
JRR
Personal Sales Rating: (4)
2003 Mitsubishi Lancer
JRR's Avatar
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
Send a message via Yahoo to JRR
Quote:
the cleaners you can get at almost any auto parts store. we have both of them where i work at.
crc MAF cleaner part no:
05110
as for the other one i cant remember the part number
josh
__________________
JR - "OK so maybe it isnt an EVO, but at least it is faster than YOURS" Quote from me to a guy with a subaru!
03 Custom Turbo Build
Base Lancer To Evo Compatibility Thread
FOR SALE:
evo parts, turbo fuel, and other things laying around the garage
Offline
Old Sep 11, 2009, 08:28 PM   #4
Ozdriver's Avatar
the throttle body have less than 30,000miles on it so I don't think that is the issue.... but I will try the maf cleaner I actually didn't even know they made such a thing. thanks for the info guys
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 11, 2009, 09:18 PM   #5
03lances's Avatar
Doesnt really matter the mileage the throttle body can be dirty after 10k I would get it just to check one less cause off but obviously all at your discretion
__________________
16G Turbo build:
Offline
Old Sep 11, 2009, 09:27 PM   #6
Personal Sales Rating: (1)
Drives: 2003 evo
sounds like a vaccum leak somewhere.
__________________
injen upper and lower i/c pipes, invidia dp, hallman mbc@28psi, megan o2 housing, gt spec manifold, buschur 20g-9-5, buschur 780 inj, hks carbon ti exhaust, ur cat delete, 255 walbro, ams licp, act hdss clutch, bc 272 cams w/hks cam gears, turboxs fmic, aps bov
Tuned by Mellon
Offline
Old Sep 12, 2009, 06:50 AM   #7
Ozdriver's Avatar
Quote:
I have checked every vacuum line and can't find a leak... that was my first thought
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 12, 2009, 08:06 AM   #8
Ozdriver's Avatar
what do you actually spray with the maf cleaner?
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 12, 2009, 09:29 AM   #9
Ozdriver's Avatar
here is a quick video of what it sounds like... not great quality but it will give you an idea of what its doing
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 12, 2009, 11:57 AM   #10
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
I would recommend resetting your ECU by removing the negative cable off of the battery for 30min. After hooking the cable back up, start the car and let it idle for 20-25min to let the ECU relearn its idle. Then drive the car easy for the next 100 miles to let it learn the rest of its settings. If this doesn't solve the issue I would maybe look at a bad coil(s), bad idle control motor or maybe your RRM throttle body BISS screw was improperly adjusted if it was on a previous Lancer.
Does your car have any sputtering or misfire like issues under light or heavy acceleration at any RPM?
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Sep 12, 2009, 01:05 PM   #11
Ozdriver's Avatar
I will try resetting the ecu again just for good measure. there is no sputtering or misfire issues under heavy or light acceleration or any RPM, no check engine light.
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 12, 2009, 04:41 PM   #12
Personal Sales Rating: (0)
kaho's Avatar
Similar idle issue happened to me as well at around 30000km. The engine rpm will fluctuate frequently upon idle sometime feeling it will almost stall. I dumped a bottle of fuel injector cleaner in the gas tank after filling up and after that tank of gas it idles fine again.
Offline
Old Sep 12, 2009, 04:53 PM   #13
Quote:
If you reset your ECU, but don't let it properly learn its idle for 20-30 minutes before driving it will have idle issues. How many miles do you have?
__________________
Offline
Old Sep 12, 2009, 05:08 PM   #14
Ozdriver's Avatar
I have just over 80,000 miles. I understand that you need to let the car idle for it to "learn"
I have cleaned my MAF reset my ECU and let the car idle for 30mins and it is idling steady now at 500rpms I adjusted the BISS so it is idling at just under 1000rpms and the car seems to be good now.... keeping my fingers crossed that it doesn't come back
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old Sep 12, 2009, 05:25 PM   #15
Personal Sales Rating: (11)
2002 Mitsubishi Lancer
02-Lancer-Es's Avatar
Drives: Lancer
My car used to do that and it was the Egr valve .
__________________
My car
Offline
Tags
cleaner, crc, evolution, maf, mitsubishi, problems
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
