RRM Timing Module Question
I just bought and installed the RRM Timing control module and I have a question with regards to mounting it. As you can see in the pic, right now, I have it mounted with some heavy duty double sided tape and zip tied like a sadistic bondage fan. The question is, is it enough? Should I drill into the frame and bolt/screw it down? It's really secure right now, but I'm worried it might come loose one day... What has everyone else used to secure it?
I did some searching but couldn't find what any one used to secure it.
As far as reviews - it is by far the best mod I have put on so far. The acceleration is nice and linear now, no more jerking as I depress the gas petal. And it now pulls all the way to the top of the RPM band, instead of puttering out as it did normally. I can't say I gained that much HP/TQ as I have no immediate access to a dyno, but it definitely feels more powerful.
__________________
2009 Graphite Gray GTS CVT
K&N SRI
Ralliart Tail lights and front grill
RRM Timing Control Box
RRM Springs
On the way: Magnaflow Exhaust
