Jul 21, 2009, 04:12 PM
Personal Sales Rating: ( 1)
Drives: 02 mitsubishi lancer es
swapped to an eclipse 501 MAF
Well, I took a hint from senate a while back about upgrading to a eclipse 501 MAF . I swapped the MAF out and used ecuflash to copy all the settings from the eclipse ecu to the lancer ecu. The settings I copied were for the MAF scaling, Maf size , Maf smoothing table and Maf Sensor filtering. Here is a picture of the differences between the two... Senate was there anything else you copied in for the maf swap?
Lancer left ----------------------------------------------------------------- Eclipse 501 right
Here is the writeup by senate figured i'd link , looks like he put some time and thought into a very nice post...
Lancer MAF Swap Step-by-Step Guide
Offline
Jul 21, 2009, 06:33 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Nope, you got it right.
I hope people will stare long and hard at this pic you posted and follow your lead to switch to the 501 MAF. I've been running a 501 MAF since Jan '07 and don't see having it any other way. You will not regret this mod. The picture speaks for itself.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Jul 21, 2009, 06:50 PM
Personal Sales Rating: ( 0)
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
So wait, this just plugs right into our harness and everything? where could I find the values to copy in with the ecuflash?
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Online
Jul 21, 2009, 07:00 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
I have wanted to do this swap since I took mine off the clean. It is so small. I just don’t have ecu flash o can you post the stock eclipse setting for those who have the 501 and ecu flash to scale it.Nice job on the swap
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Jul 21, 2009, 07:10 PM
Here are the values from an 2001-2003 Eclipse GS ROM:
__________________
Offline
Jul 21, 2009, 09:45 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
no adaptor required?
anyone know the part number?
Online
Jul 21, 2009, 09:56 PM
Nope. No adapter required. They are the same exact size. Difference is in the inside. The Mitsu part # is MD336501, if that helps. Just look for the big "501" on the label. The Evo is 399, just for reference.
__________________
Offline
Jul 21, 2009, 10:13 PM
Awesome. Thanks
Online
Jul 21, 2009, 11:09 PM
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
so from what im gathering other than this is a no brainer mod to put in, what years eclipse is this off of? i gotta run to the salvage yard on friday anyway!
Offline
Jul 22, 2009, 06:30 AM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
Quote:
No brainer to install a maf.
You need a little more to copy values from one ecu to another.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Jul 22, 2009, 06:43 AM
+1
While the MAF install itself is plug and play, if you don't know how to properly use EcuFlash you run the risk of messing up your ROM.
The 501 MAF was found roughly on the following vehicles:
ECLIPSE 00-02
ECLIPSE 03-05 exc. GTS
GALANT 99-03
MONTERO SPORT 99-03 3.0L (6 cyl)
OUTLANDER 03
SEBRING 01-05 (Coupe)
STRATUS 01-05 (Coupe)
After looking through the Mitsu parts lookup last night I realized that the 501 MAF is not limited to 4-cylinder engines. For example, the 501 MAF was used in the 2000-2002 Eclipse GT, which is a V6.
__________________
Offline
Jul 22, 2009, 11:21 AM
no brainer as in the size wize. i didnt mean it was going to be anything as a drop n go style. i know that you have to change values in the ecu.
Offline
Jul 22, 2009, 12:29 PM
Drives: Yellow OZ
Maybe you know. But some kindergarden kid who read your post may think it's as easy and swap and go.
__________________
Offline
Jul 22, 2009, 01:14 PM
OMG im so happy. My mom wrecked her 02 montero sport and its sitting in her front yard completely totaled with engine intact. Thanks for the list on that.  Yay!
__________________
Online
Jul 22, 2009, 01:20 PM
hopefully some kindergarten kid wouldve been smarter than that because if you read the thread so far senate posted some values that you need to change. that and this thread hasnt hit 2 pages yet.
Offline
Tags
02, 399, 501, clutch, compare, eclipse, evo, lancer, maf, mod, oz, rally, resistor, sale, swapping  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
