Jul 5, 2009, 04:04 AM
Personal Sales Rating: ( 0)
Drives: 2002 Mitsubishi Lancer OZ-Racing RallyEdition
Dent + Oil Pan = Bad Lubrication ???
i have an 02 oz lancer
it looks like the lowest part of the oil pan is dented (or is that just how it looks?)
i tried searching the forum but only learned that there is an upper and lower oil pan (maybe didn't search good enough)
so i guess the dent is on the lower pan
my question is...
Does having a dent in the lower pan effect the oil pickup?
Will the dent hinder lubrication?
i ask this because with nissan's sr20 engine the oil pickup is really close to the bottom of the oil pan and a dent in the pan can close the clearance gap between the pan and the bottom of the oil pickup, restricting oil flow.
is the pickup in the lancer engine like an upside down soup bowl like the sr20? or is it a half sphere metal screen?
any help would be awesome, thanks
Offline
Jul 5, 2009, 10:08 AM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
The oil pickup sits pretty close to the bottom of the lower oil pan. I would change or repair your lower oil pan right away as the dent WILL cause lubrication issues. Depending on how big the dent is it may have also dented the pickup. Remove the ten M10 bolts that hold the lower oil pan in place and inspect the oil pickup. If the pickup is good and the pan is not too bad after removal, take a hammer and pound the dent back out.
Offline
Jul 6, 2009, 02:22 AM
after getting the car in the air and cleaning the pan up i can see that the deflection is less than 1/8th of an inch (or so it seems)
if the head was starving for oil would i hear valve noise?
where can i read about the 4G94??? (is that my engine???)
i wanna learn about the head design and what not
also thanks for the advice
Offline
Jul 6, 2009, 02:47 AM
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Now wait, is this actually a dent? Cause the LOP is not flat on the bottom. Can you provide pics? And yes you would definitely hear valve noise from oil starvation. Ugh bad times.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Jul 14, 2009, 03:25 AM
sorry i took so long to get back
ive come to the conclusion that the pan isnt dented as bad as i thought
its a factory bend and the pan is a lil scratched up
the dent is minimal and the lifters arent unusually noisy so im just gonna leave it be
thanks for helping
Offline
Aug 4, 2009, 09:25 PM
Drives: 1968 Pontiac Firebird, 1991 Camaro, 2003 Lancer OZ
I dont like the location of the oil pan seems like if you drop a curb it will dent. I would rather have a crossmember in the way.
Offline
Tags
2002, close, dent, dented, lancer, mitsubishi, oil, oilpan, oz, pan, pickup, racing, rally, repair, screen  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
