Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 8, 2009, 08:06 AM   #16
Personal Sales Rating: (0)
Drives: 2009 Ralliart
There should be spec sheets of engine internals for both the 4B11/4B12 and 4B11-T, research them, find your own answers.
Honestly, how much power can you actually put down on the ground with the 2.4. With no LSD, a weak transmission, suspension and brakes. The TC-SST is no beast, and the brakes could use a little help, but to even perform to the low standards of a R/A, you must put down R/A money or more to match its marks.
Offline
Old Jul 8, 2009, 08:12 AM   #17
1998 Mitsubishi Eclipse
My Garage
GPTourer's Avatar
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
Send a message via AIM to GPTourer
The cost of stroking a 4b12 would be high. Everything would have to be custom made and the most expensive part would be the crankshaft. You might be able to get it to 2.6L but that would be pushing it, because I'm thinking that the block's integrity would be compromised by boring it out that much. And then you'd have an engine that wouldn't rev very high like otter has said and you'd end up with a car that isn't very fast.
Bottom line is I think this is a bad idea. A turbo kit is a much more cost effective solution.
__________________
Skeet
Driven to Thrill
Offline
Tags
24, 300zx, 4b11, 4b11t, 4b12, block, buy, cams, cylinder, deck, engine, evo, kit, make, power, stroker, valves
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
