Jun 15, 2009, 07:28 AM
Personal Sales Rating: ( 0)
Drives: Mitsubishi Magna 2000
Billet 70mm Throttle Bodies for those interested
RPW has been working with a new company and now has billet 70mm throttle bodies available.
These are available as a direct bolt onto virtually all Mitsubishi model vehicles, but more importantly, are a direct bolt on for the USA Lancer vehicles.
For the 4G94 Owners, you woudl either need to use the EVO 7-9 model throttle body whic has the correct TPS switch fitment and choke housing base.
We have just started using these products, and I can only say the qaulity of these are absoloutly amazing.
I will not link it to our website, because that may invoke the moderators of the forums. Same with pricing.
Below is a photo for those interested.
__________________
Racing Performance Works - Mitsubishi Specialists. Check our website if you want to know more.
Offline
Jun 15, 2009, 10:44 AM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
awesome! Will this have a matched intake manifold in the future?
Offline
Jun 15, 2009, 10:58 AM
We can make custom manifolds as well yes, with larger plenum chambers, internal ram tubes etc.
__________________
Offline
Jun 15, 2009, 02:32 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
I'm confused. You say they are a direct bolt on to the 4G94. But you also say that we need to use the Evo 7-9 model throttle body. Does that mean we need an Evo TPS or an entire Evo throttle body?
Offline
Jun 15, 2009, 02:35 PM
Personal Sales Rating: ( 9)
Drives: 2005 WW Evo VIII, 1993 GMC Typhoon, 1995 Eclipse GSX
Nice! I'd be curious what the prices are compared to the new Boomba TB.
Offline
Jun 15, 2009, 07:22 PM
EVo 7 - 9 TPS is the same as the 4G94 TPS design, hence why you don't need to modify anything for them to fit the 4G94. Pricing for these are around $450.00 AUD$ approx
__________________
Offline
Jun 15, 2009, 07:31 PM
So doing a currency converter looks like $355 US plus shipping. Thanks!
Offline
Jun 19, 2009, 02:07 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
very nice :P
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Jun 23, 2009, 06:47 AM
So we need to use an Evo TPS or our Lancer TPS? The connector is different. Evo is 4-pin like Mirage and DSM, our TPS is a 3-pin. Also, how does the ISC motor work? Do we need one from an Evo or do we use our stock 4G94 ISC?
Offline
Jun 23, 2009, 09:26 PM
You don't need to change any TPS at all. You use your origonal TPS switch, the machined fitting on the throttle body is identical to whats on the stock 4G94 throttle body
__________________
Offline
Jun 23, 2009, 09:49 PM
And what about the ISC?
Offline
Jun 23, 2009, 09:54 PM
These units are made so that you transfer your exisiting idle speed control motor housing across or with the late model 1 piece units, you just fit your exisiting ISC motor straight into the throttle body
__________________
Offline
Jun 23, 2009, 11:05 PM
Awesome. Thanks for all the info! Should make for a promising throttle body upgrade for those who can't utilize the 75mm throttle body upgrade from Boomba Racing.
Offline
Jul 25, 2009, 09:57 PM
anyone install one of these yet? if so what did you think how do you like it?
__________________
Needs injectors
Offline
Jul 26, 2009, 11:24 AM
Quote:
A 70mm throttle body is pretty much overkill unless you're running high boost on a built engine. It wouldn't really be beneficial to an NA Lancer to increase the throttle body diameter over 5/8" (16mm).
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Tags
02, 70mm, billet, bodies, body, custom, eclipse, evo, evolution, lancer, maf, oz, rpw, throttle, upgrades  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
