Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 6, 2009, 01:38 PM   #1
Personal Sales Rating: (0)
2005 Mitsubishi Lancer
Drives: 2005 lancer es
Fuel
Could i put the subaru 440cc injectors and the Walbro 255 pump in my 05 es without a turbo? would i need a piggyback?
Offline
Old Jun 6, 2009, 01:50 PM   #2
Personal Sales Rating: (1)
bcollinstex's Avatar
Drives: 2002 Lancer OZ
I'm curious, why are you doing this without a turbo?
Offline
Old Jun 6, 2009, 01:53 PM   #3
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
+1
No need to install those without the fuel needs of a turbo setup.
Offline
Old Jun 6, 2009, 02:12 PM   #4
Haha...i'm actually planning on adding a turbo at some point. My car has been sort of deadening at times during acceleration....and it feels like fuel. So i was wondering if i could do the fuel upgrade prior to the actual turbo install, or if i had to +T it first is all.
Offline
Old Jun 6, 2009, 02:31 PM   #5
Quote:
Then get a wideband and do some tuning for fuel/ignition. Lancers do have a flat spot that is easily smoothed out with EcuFlash.
Offline
Old Jun 6, 2009, 02:33 PM   #6
Personal Sales Rating: (18)
White_KnightOZ's Avatar
Drives: 02 OZ Rally
I am all about doing as much as you can for the turbo set up, before you actually drop in the turbo, but i wouldn't really mess around with the fuel before the full install. it would just cause you to run suuuper rich, esp if a Walbro and 440cc injectors are all your going to be running. you'd be getting like 5 miles a gallon. Try some of that fuel line/injector cleaner they sell at auto stores, i use that stuff like once every 3-4 months to clean my system out.
Offline
Old Jun 6, 2009, 02:35 PM   #7
whats a wideband?
Offline
Old Jun 6, 2009, 02:38 PM   #8
Drives: 02 OZ Rally
A nifty gauge that tells you your air to fuel ratio, so you can see when you are running too rich, and ECU flash is for tuning yourself back down to a ratio more around 12:1 so you dont start frying your engine
Offline
Old Jun 6, 2009, 02:48 PM   #9
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
No, install them at the same time you do the turbo.
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Online
Old Jun 6, 2009, 02:52 PM   #10
nice. i'll check it out thanks guys.
Offline
Old Jun 22, 2009, 07:13 PM   #11
sheezy'sES's Avatar
Drives: 2003 Lancer ES
Send a message via AIM to sheezy'sES
i agree with everyone above. add the fuel mods the same time as the turbo. have someone fix your fuel problem first.
Offline
Old Jun 24, 2009, 10:29 PM   #12
Personal Sales Rating: (2)
2002 Mitsubishi Lancer
*02Lancer*'s Avatar
Drives: 02 lancer oz 74/76/79 Corvettes
I would use the injector cleaner and see if that fixes it first. And if you cannot reflash your ecu and monitor whats going on i would just wait till turbo to put bigger injectors in but if you can monitor and correctly sey your fuel i dont see why you cant put them in when your still NA.
__________________
Budget Turbo :P
installed
Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand
16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs
injectors
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
