Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 16, 2009, 10:23 AM   #1
Personal Sales Rating: (0)
2003 Mitsubishi Lancer
jarred88's Avatar
Drives: 2003 Lancer OZ rally
Unhappy Still running rough
Hey guys, i have a 03 OZ with 117000 miles and a rough idle and ive tried SO much to fix it and i cant figure it out,
i have:
bought a new catalytic converter, [the second one]
new 02 sensor
checked all my intake!
and i have NO check engine light, i just put in the o2 sensor and the engine light went off, any ideas?
Offline
Old May 16, 2009, 12:14 PM   #2
Personal Sales Rating: (3)
Ozdriver's Avatar
Drives: 2003 lancer oz
Send a message via AIM to Ozdriver
how do the plugs look?
__________________
http://www.cardomain.com/ride/2318796
http://www.myspace.com/crit_wilson
speed kills live forever drive a honda
YOU"VE GOTTA PAY TO PLAY
this is what I have so far:
aem intake
RRM intake manifold
RRM throttle body
RRM high flow fuel rail
RRM header
greddy evo 2 exhaust
magnacor plugwires
light weight underdrive pully
SAFC2
tein stech springs
RMR strut braces front and rear upper and lower
Offline
Old May 17, 2009, 08:26 PM   #3
jarred88's Avatar
there brand new! i bought them recently.
Offline
Old May 17, 2009, 08:43 PM   #4
Ozdriver's Avatar
was it doing this before you replaced the plugs? what did you get for plugs?
have you checked all your vacuum lines? what do you mean by running rough? what is it doing exactly? is it just at idle does it get better or worse at different rpms?
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old May 17, 2009, 08:44 PM   #5
jarred88's Avatar
ive checked them, it idles slightly rough at 700, then from 800-1100 it REALLY rough and loud, then runs out smooth,
Offline
Old May 17, 2009, 08:47 PM   #6
jarred88's Avatar
it did it when i bought the car, and i went with basic plugs, single prong copper plugs
Offline
Old May 17, 2009, 08:59 PM   #7
Ozdriver's Avatar
did you check to make sure the plugs were properly gaped?
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old May 17, 2009, 09:02 PM   #8
jarred88's Avatar
i did gap them correctly but it wouldnt hurt to check, any other ideas? ive gone through so many typical fixes
Offline
Old May 17, 2009, 09:08 PM   #9
Ozdriver's Avatar
did u try resetting the ECU yet? its a long shot but easy enough to try..... maybe injectors could be a bit gummed up. there are lots of reasons you could be having this problem its hard to say without being able to see/hear the issue (at least for me)
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old May 17, 2009, 09:09 PM   #10
jarred88's Avatar
yeah well ive heard of cleaning injectors and stuff but i dont know how to do that kind of stuff. but i havent reset the ECU
Offline
Old May 17, 2009, 09:20 PM   #11
Ozdriver's Avatar
to reset your ecu disconnect your battery for a few mins reconnect and you should have reset.
I would toss can of seafoam in your gas tank next time you fill up to help clean everything out.
could be bad ignition coils? dunno just throwing ideas out there
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old May 17, 2009, 09:36 PM   #12
jarred88's Avatar
i appreciate it! ill post on the results
Offline
Old May 17, 2009, 09:52 PM   #13
Personal Sales Rating: (1)
coal's Avatar
Drives: Lancer ES
Timing belt?
__________________
Amsoil 0W-30
Amsoil EAO13 Oil Filter
RRM SRI
RRM Slotted Rotors
RRM Header
RRM check engine light eliminator
Cat back exhaust by Portland muffler
RDD front strut bar PC black
RDD rear strut bar PC black
RDD trunk bar PC black
RDD rear tie bar
Ported intake manifold
Magnacore plug wires
Offline
Old May 18, 2009, 02:55 PM   #14
Ozdriver's Avatar
Quote:
Originally Posted by coal View Post
Timing belt?
you think his timing could be off? or that his belt could have skipped a tooth? I would think that would cause a lot more problems than what he is experiencing but then again I could very well be wrong.
any updates with your issue?
__________________
aem intake
RRM intake manifold
RRM throttle body
RRM header
magnacor plugwires
SAFC2
tein stech springs
Offline
Old May 18, 2009, 06:12 PM   #15
jarred88's Avatar
well now im having a slight bit of trouble getting it started. narrow it down?
Offline
Tags
rough idle
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
