Apr 20, 2009, 05:21 PM
Personal Sales Rating: ( 1)
Drives: 02 Lancer ES
4g94 gasket specs
i just discovered that i have an intake leak.. me and my friend just found it out. not all 4g93 IM is the same.
i got the other version of it not sure which one though but its the one that gonna give u an intake leak.
he suggested that i need a thicker gasket made with metal and bigger hole. (60mm)
so what are the specs of the 4g94 intake gasket?
thnx guys.
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Evo Style Grille v4.0
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]NGK Iridium plugs
[X]4g93 Mani Stage 2.5
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]15" Konig Heliums
[X]EcuFlash
[X]Slotted n Drilled rotors
[X]501 MAF (not installed)
[X]Shorty Rear Bumper
[ ]///RRM TB
[ ]Progress Rear Anti Sway Bar
[ ]///RRM RalliSpec X bar
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 07:53 PM
Personal Sales Rating: ( 3)
Drives: 04 4G69 (daily) 97 Mirage 4G63 powered (fun)
Uhhh what? I've had 3 4G93 IMs and they were all the same except for the vacuum ports / outlets on it.
__________________
Daily driver: 4G69 powered Ralliart Lancer
Fun car: 4G63 powered 5th Gen Mirage
Offline
Apr 20, 2009, 07:57 PM
Quote:
mines different than Rhyzins..
but anyways how can fix the freakin leak?
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 07:58 PM
Well what TB are you using? Get the gasket for that TB (if you're running a 60 mm TB as it sounds like you are, get one of those) ....
That is, if you're sure it's leaking from the intake manifold and the TB.
__________________
Offline
Apr 20, 2009, 08:00 PM
im using the stock tb..
maybe i need a new gasket?
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 08:07 PM
I guess my first question is, are you sure it's leaking from the intake manifold? How are you so certain?
__________________
Offline
Apr 20, 2009, 08:10 PM
its between the IM and TB. (where it connects)
Rhyzin's the one who found about it.
EDIT: he used the PB blaster technique. also when he put his finger at the IM, TB connection, the vacuum sound lessens..
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 08:17 PM
Hmmm... I dont think the Lancer gasket was any smaller than the Mirage. But who knows. I'm all for the cheap / free fixes first. I'm sure you've tried bolting it down pretty good, esp. the lower bolts that are awkward to reach, and the gasket is in good condition?
Outside of that, get a new gasket. They should be about 3 bucks and that would eliminate one potential problem.
__________________
Offline
Apr 20, 2009, 08:22 PM
thats what im thinkin that might fix it..
btw the leak is at the top right side of the connection. (top right bolt, facing the firewall)
imma call mitsu tom after work.
also thnx for helping me man.
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 08:25 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Throttle body gaskets are not meant to be re-used on the 4G9x engines. Also make sure that you install the gasket the right way. It has to be oriented a specific way. See the diagram.
Offline
Apr 20, 2009, 08:29 PM
Quote:
i installed it the right way.. i guess i just need a new gasket..
if that didnt work, any ways to fix it?
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 20, 2009, 10:32 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
About the manifold being different. could it be a 4g15 sohc intake manifold i got the wrong one at first but got that fixed. Here check this out and see if it looks like my old 4g15 intake intake manifold upgrade? Hope that helps
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Apr 20, 2009, 11:21 PM
EDIT: imma check it tom.. maybe were the same.
EDIT: its not.. i have a g93.
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Tags
4g15, 4g63, 4g94, diagram, engine, evolutionm, exhaust, gasket, gaskets, manifold, mitsubishi, parts, ports, specs, upgrade  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
