Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Tech
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Feb 22, 2009, 01:39 PM   #1
Personal Sales Rating: (0)
2003 Subaru Impreza WRX
My Garage
abevAWD's Avatar
Drives: '03 Subaru Impreza WRX, '03 Mitsubishi Lancer Evolution VIII
Points: 3,757, Level: 38
Points: 3,757, Level: 38 Points: 3,757, Level: 38 Points: 3,757, Level: 38
Daily Activity: 2.4%
Daily Activity: 2.4% Daily Activity: 2.4% Daily Activity: 2.4%
swankylaxplayer abevAWD swanky
oil change info - interesting read
I'm not sure how many people know this information, but its definitely good stuff to know. I myself just found this out yesterday.
Anyway my girlfriend and I noticed that the Lancer feels noticeably peppier after oil changes while my gs-t and all my previous cars would feel no different after getting the oil changed. Yesterday I had this explained to me by someone at work: The variable valve timing in engines such as MIVEC, VTEC, VVT-I, etc. is dependent on the oil to operate at full performance. Most VVT engines take 5w20 oil because that grade works the best with the VVT; but 5w20 breaks down very easily because it is so thin. Usually, by the time you get your oil changed, the oil has begun to break down; so when you put new oil in the engine, the car feels peppier from the "fresh" oil.
So knowing this, it would make sense that if you wanted the best possible performance from your engine it is very important to:
Change the oil at regular intervals.
USE 5W20. If thats what the engine calls for - use what the engine calls for.
Use synthetic oil. Synthetic oil takes much longer to break down than conventional oil does. Also, it would be good to research and find out what synthetic oil brands are known for lasting the longest.
Most of that is common sense, but that hasn't stopped people from ignoring it before
Offline
Old Feb 22, 2009, 03:02 PM   #2
Personal Sales Rating: (2)
Garage is empty, add now
krnkimchi702's Avatar
Drives: 95 jeep cherokee sport
Points: 9,232, Level: 64
Points: 9,232, Level: 64 Points: 9,232, Level: 64 Points: 9,232, Level: 64
Daily Activity: 1.2%
Daily Activity: 1.2% Daily Activity: 1.2% Daily Activity: 1.2%
pandamonium702
well the weight of oil can be controversial.. it depends on the variables. people who live in the desert use 10 w 30 while people in cold temperature use either 0-30 or 5w20
__________________
Post # 222,222 on APW
Quote:
Originally Posted by andyktlee View Post
Herro? My name Byung with Areejona. I call to ask *CLICK*
Herro? Herro?
Quote:
Originally Posted by The_Shocker View Post
<3 byung
Quote:
Originally Posted by pwrofturbo View Post
And ATT 3g coverage there might as well be powered by native americans sending data packets using smoke signals.
Quote:
Originally Posted by Basalix View Post
내 이름의 병, 내가 아기를 먹는 것
Offline
Old Feb 22, 2009, 03:10 PM   #3
I Am God's Avatar
Drives: 09 Black GTS M/T S&S
Points: 2,874, Level: 32
Points: 2,874, Level: 32 Points: 2,874, Level: 32 Points: 2,874, Level: 32
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
what about how mitsu says to change oil at 3750...thoughts? cuz i got the vip 2 year free oil change thing...i dont think theyd change it for me for free if i started goin in every 3000 miles
Offline
Old Feb 22, 2009, 05:09 PM   #4
Personal Sales Rating: (1)
2008 Mitsubishi Lancer
nj_08_gts's Avatar
Drives: 2013 Mazda CX-5 Grand Touring
Points: 4,084, Level: 40
Points: 4,084, Level: 40 Points: 4,084, Level: 40 Points: 4,084, Level: 40
Daily Activity: 6.2%
Daily Activity: 6.2% Daily Activity: 6.2% Daily Activity: 6.2%
5W-20 oil is used for fuel economy purposes...it really doesn't have anything to do with variable timing. I can name 20 cars with VVT where you will never find anything close to 5W-20 in the sump. The "feel" of the car, along with MIVEC, will be exactly the same if you use 0W-30, 0W-20, 5W-20, or 10W-30. What you decide to use depends on preference or, like krnkimchi702 said, climate.
And no research is needed: Amsoil will blow away any other synthetic oil in terms of protection and durability
__________________
"Speed has never killed anyone - suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Offline
Old Feb 22, 2009, 07:08 PM   #5
My Garage
abevAWD's Avatar
Quote:
Well, yeah thats true. I should have said where climate allows.
Quote:
I meant regularly, and at a reasonable interval. In most cases, the car manufacturer's recommended interval is a good guideline to follow. I just meant not changing the oil every 6k+ miles - if you're looking to constantly have the best possible performance. In terms of taking care of your engine, I would say going every 6k miles with synthetic would still be fine if you did it regularly. Thats mostly my opinion though - don't take it as me telling you a "rule" or something.
I agree with your general statement, and I also know that not every VVT engine uses 5w20 - Toyota VVT-I's for instance - but I would have to say that if you kept putting 10w30 in your MIVEC/VTEC/whatever you would feel a difference over time that you wouldn't feel had you put in the recommended grade oil. That statement assumes a climate where 5w20 is suitable.
And as for Amsoil, I've heard conflicting things about it. Many people such as yourself say that its the only oil to consider, while i've also heard quite a few people say not to go near it. Kind of like Royal Purple, where people either love it or hate it.
Offline
Old Mar 5, 2009, 11:42 AM   #6
Personal Sales Rating: (4)
2009 Mitsubishi Lancer
Lancer09mx's Avatar
Drives: 2009 Lancer ES+T, 2006 Suzuki GSXR1000
Points: 3,399, Level: 36
Points: 3,399, Level: 36 Points: 3,399, Level: 36 Points: 3,399, Level: 36
Daily Activity: 0%
i always go to the dealer just becuase the warranty
__________________
Lancer ES MT 2009 mods:
www.robgarcia.me
www.youtube.com/robgarcia85
Offline
Old Mar 17, 2009, 09:17 PM   #7
humblehyper's Avatar
Drives: 2010 Mitsubishi Evolution with SSS
Points: 2,436, Level: 29
Points: 2,436, Level: 29 Points: 2,436, Level: 29 Points: 2,436, Level: 29
Daily Activity: 0%
How come the manual on my 2009 Lancer GTS says interval of 7,500 miles before oil change. Should I follow this or depends on where you live? I don't live in harsh area like the desert or something, and it doesn't snow here either
Offline
Old Mar 17, 2009, 09:29 PM   #8
SyZyGy1394's Avatar
Drives: TB IX MR SE
Quote:
Thats ridiculous! It takes around 30 min to do yourself and is a breeze! They can't take away your warranty for something as simple as that. Just do it right, keep your receipts, and use oem oil filters.
Quote:
I'd just do it at every 3k...
__________________
E85
My trouble senses are tingling...
Quote:
Originally Posted by nekkidlad View Post
i have the injen SRI on my car...i dont know about a bo valve sound when u let go the gas...but i do know when ur getting up in the rpms close to and past mivec it does have a nice whistle to it...(alsmost bo valve like)...
Offline
Old Mar 17, 2009, 10:07 PM   #9
I Am God's Avatar
Daily Activity: 0%
yea my gts said the same thing..i didnt hold to it tho i dont know wtf that mark is for..oil change every 3750 like the manual says...i got the 2 year vip thing free oil changes for 2 years, 2 free details, once a year...they still charge me for tire rotation tho...
i dont think theyd still do the free-ness if i went in every 3000k...
Offline
Old Mar 18, 2009, 10:21 AM   #10
SyZyGy1394's Avatar
Drives: TB IX MR SE
Well, you should rotate your tires/wheels yourself. Very easy! Now putting your tires in the opposite direction(if they are unidirectional) so you can swap them with the ones on other side of the car is a different story.
__________________
E85
Offline
Old Mar 18, 2009, 10:36 AM   #11
2008 Mitsubishi Lancer Evolution
Webman's Avatar
Drives: 08 EvoX MR
Points: 6,211, Level: 51
Points: 6,211, Level: 51 Points: 6,211, Level: 51 Points: 6,211, Level: 51
Daily Activity: 0%
Red the manual again. It clearly explains all of that stuff. Lancer GTS recommended changes are every 7500 miles or 6 months (normal driving). Since I never drove mine more than 7500 miles in 6 months, I changed it at 6 months. Then I traded it in before I had to change it again, lol. I also switched to synthetic at the first oil change.
__________________
08 Evo X MR - Replacing the Rockford stock stereo
08 Honda CBR600RR
02 Yamaha WR250R
95 Toyota Tacoma
Offline
Old Mar 18, 2009, 12:38 PM   #12
I Am God's Avatar
Daily Activity: 0%
im goin by severe maintenance...
Offline
Old Mar 18, 2009, 04:16 PM   #13
djslik408's Avatar
Drives: 2005 Evo & 2008 Lancer GTS
Points: 4,687, Level: 43
Points: 4,687, Level: 43 Points: 4,687, Level: 43 Points: 4,687, Level: 43
Daily Activity: 0%
Send a message via AIM to djslik408
Another factor also is how your drive the vehicle and certainly is it more street driving or freeway. There is nothing wrong with checking your oil either before the 3k mile or every once in a while. I know on my evo8 depending on how I drive it, the oil gets really dark quick (on track days).
Offline
Old Mar 29, 2009, 12:35 AM   #14
Drives: 09 WW Ralliart
Points: 3,888, Level: 39
Points: 3,888, Level: 39 Points: 3,888, Level: 39 Points: 3,888, Level: 39
Daily Activity: 4.2%
Daily Activity: 4.2% Daily Activity: 4.2% Daily Activity: 4.2%
jonhix666
just wanted to add this...if you have a GTS and lower...there is NO NEED to buy royal purple oil....that **** is 10 bucks a quart and wont get you more HP......
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
0w20, 95, car, change, es, evolution, forum, grade, gst, gts, interval, intervals, lancer, mitsubishi, oil, peppier
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
