Dec 29, 2007, 09:38 AM
Personal Sales Rating: ( 88)
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
4B11 specs
Bore - 86mm
Stroke - 86mm
Rod length - 149.25mm
Rod ratio - 1.735
Deck height - 230.1mm
Internals - forged H-Beam carbon-steel rods connected to aluminum alloy pistons.
Block is open-deck.
More to be added as I come across it. PM me or post up if you have info.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Jan 15, 2008, 09:24 AM
Personal Sales Rating: ( 0)
2008 Mitsubishi Lancer
Drives: Lancer 2008 GTS
Is it confirmed that the 4b11 (non EVO) engine has forged rods
__________________
Current MODs:
XenonDepot 3000k (Low) - Injen CAI - Custom 2.25" Dual Exhaust - Side License Mount - HOS Urban Fr and Rr Lip - Tints: 22% 5% - LED Side Mirror - 18" MSR Style 045 - Scorpion V-LIP - 3 Piece Spoiler - ASW 4-2-1 - KVR CF Brake Pads - KVR J Hook Rotors (Silver)
Next:
XenonDepot HID 3000k (fog) - ASW Engine Dampener
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Offline
Jan 15, 2008, 09:52 PM
Drives: 2010 PB Evo X MR Touring
Quote:
yes
Offline
Jan 16, 2008, 01:12 PM
Personal Sales Rating: ( 10)
Drives: Part-Time Test Mule
Forged H-Beam carbon steel rods connected to aluminum alloy pistons.
Offline
Jan 17, 2008, 10:24 PM
Drives: Apex Silver 2008 Lancer GTS
I'm sure there will be some structural enhancements to the evo and RA engines so that it can handle much higher boost levels. However, from the info released so far on the 4B11 and 4B11T engines it seems they are very similar in component construction. Plus the chance that the RA and Evo crankshafts and other parts will easily fit on the standard 4B11 engine with little to no modification seems high. This might be wrong section for this but it does have to do with specs
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Jan 27, 2008, 12:42 PM
Drives: 2008 lancer GTS
engine balance
is the engine internally balanced or externally. i have a few worries with the RRM lightweight alluminum pulley i ordered and the balance issue
Offline
Jan 27, 2008, 12:50 PM
The stock pulley does act as a balancer, but it isn't the only one. There are also balance shafts inside the motor.
__________________
Modern Warfare 2
Offline
Jan 27, 2008, 12:58 PM
Drives: 2008 Lancer GTS 5 spd w/ sun&sound
Quote:
Its NOT a balancer, and having an internally balanced engine doesn't have anything to do with the rrm pulley!!!!!
Your stock DAMPENER/pulley is used to reduce TORSIONAL vibrations on the crank. Thant its the twisting and untwisting from power stokes from the pistons. Balanced engine or not you still have those torsional vibrations!!! The stock pulley dampens these twisting vibrations thus extending the life of your crank.
Offline
Jan 27, 2008, 01:09 PM
I stand corrected, then.
__________________
Modern Warfare 2
Offline
Jan 27, 2008, 01:16 PM
Although this is kinda off topic for this thread and may belong in the RRM thread.
To sum this up for those at home who have no clue what this means? in regards to wewalkalone87's question.
__________________
Current MODs:
Next:
Offline
Nov 21, 2008, 12:19 PM
Drives: '08 Lancer CVT ES-GT
I've had the RRM pulley installed for over 30k and I've had no issues... I have noticed the increase in TQ at idle in Drive stopped, not moving. The accessory kicks in and the car wants to jump a little when the alternator initially kicks on and starts charging. Keep your foot on the brake...
__________________
JoeyBallGame
'08 CVT Lancer ES-GT Silver Metallic
[x]5-15% Performance Tint
[x]RRM Pulley
[x]RRM SRI
[x]MagnaFlow Axle Back Exhaust
[x]1st Brake Upgrade
[x]RRM Chassis Braceing Kit
[x]RRM Rear Sway Bar
[ ]17" Lite Wt. Wheel & Tire Combo (Spring '10)
[ ]Pruven Performance Custom Engine Tuning
[ ]RRM Motor Mounts
[ ]RRM Coil Over Adjustable Suspension
[ ]RRM CVT Turbo w/ Trans Cooler
[ ]RRM CarbonFiber Covers & Hood
[ ]EVO Body Kit & New Paint Job...
Offline
Nov 21, 2008, 12:38 PM
Turbo vs. RA
Quote:
Can anyone tell us the differences in the 4B11 & the 4B11T engines, if any...?
The reason I'm asking is if I'm going to install a turbo in my 4B11 CVT ES, I'm going to want to upgrade some key components to take the extra loads of a turbo or any other upgrade...
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Nov 21, 2008, 02:50 PM
Drives: 2008 Mitsubishi Lancer
Quote:
Originally Posted by JoeyBallGame
Basically just the internals like: bigger injectors, different pistion compresson, camshafts etc...
__________________
Cam
[X] RRM Pully
[X] 5% tints
[X] 2 12in jensen subs 1600watts
[X] Custom trunk/ interior paint
[X] 8000k hids and led park lights
[X] Custom Duels
[X] Custom CAI
[X] Vortex genz
[0] CustomTurbo
First turboed CVT 08 in Miami ( UNTUNED) no longer installed =/
Offline
Nov 21, 2008, 05:27 PM
I am just about to run out the door, but there are Mitsubishi Technical videos for both the 4b11 and T versions, if you poke around on youtube or if someone can provide some direct links, The technician does a good job at explaining the differences.
__________________
Current MODs:
Next:
Offline
Oct 25, 2009, 08:59 PM
Drives: Lancer DE, DAKOTA R/T
what psi can the 4b11 handle for a DE/ES if you do go turbo? and how much do you have to lower the compression to install a turbo?
Offline
Tags
08, 4b11, 4b11t, balance, carbon, evo, fiber, increase, interiors, internals, lancer, modification, power, shafts, size, specs, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
