Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Dec 21, 2006, 09:36 PM   #1
Personal Sales Rating: (1)
Garage is empty, add now
Points: 7,773, Level: 59
Points: 7,773, Level: 59 Points: 7,773, Level: 59 Points: 7,773, Level: 59
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Post DIY Individual Throttle Body Setup.
Done on a Honda Engine, but concept is exactly the same. I think it's a worth wild to post and fairly easy to do with some adventure.
Click the image to open in full size.
Starting off with a set of 2001 Suzuki GSX-R Throttle bodies. I picked up this set on ebay for very cheap! 50 bucks. The spacing looked about right, I think it was about 80mm, perfect for alignment on the B-series head.
Measureing at 42mm @ the butterflys and tapers to a 45mm (which also had secondary butterflys that were taken out).
The stock manifold was chopped off slightly after the fuel rail mounts, I then had 1 1/2 inch long aluminum runners welded on (1.75od) After the welded I had the manifold surfaced on both sides, and threw a chanfer on the lips of each runner. (75 dollars weld/machine work)
Here are the cheap *** velocity stacks I got on ebay, they were 35 bucks. used some small machine screws to fasten them down. Looks kinda cheezy, but they do the job.
These are the silicone couplers that attach the Throttle bodies to the intake manifold. Sounds kinda half *** huh? well the factory Suzuki ITB's are this way, and most other bikes too! And after attaching them they were very sturdy. I used Napa bulk Silicone hose, with some hose clamps. (20 bucks from Napa)
The Cover shield that hides the linkage and other stuff, just cosmetic.
The factory ITB Fuel injector bungs were JB welded shut, except for the last one which has my brake booster port coming out. You can also see the map sensor signal lines, each port all T's into one and goes to the map sensor.
Thought it looked long? so did I, but after measureing up with the stock manifold, I felt a bit better, I thought for sure the stacks would be touching the firewall, but its actually just a bit shorter than the stock manifold.
The TPS situation, well the Suzuki tps had a way differant range than the stock honda one, I tried to make it work, but it just wasnt happening, So the stock honda one had to be modified to fit somehow.
First I made a baseplate with a hole saw and some scrap aluminum. This is on the backside of the shaft (driverside)
The Brass fitting, was bored out to be a custom bushing for the shaft.
The Shaft is actually a honda throttle body shaft cut down about 1/4
Now for mounting, I used a piece of PVC pipe to space out the tps, so it could mount solid.
Hoggered out the holes on the base plate a bit, so I could get a good amount of adjustment.
Used some extra long machine screws to mount it down
All mounted down, Its very secure and pretty easy to adjust.
Now setting the TPS up in the correct range. Stock TPS setting @ closed .4 - .5v
Stock setting WOT about 4.5v
Best I could get the ITB TPS was .6 @ closed
and 4.4 @ WOT
The throttle linkage was alot easier than I thought! I used an extra throttle bracket from a D16a6 intake manifold, and it fit right off the backside perfect!
This kinda pissed me off, I mounted the TPS upside down, it was hitting the master cylinder. So I had to rotate it, and re-adjust it.
Overall, for a couple hundred bucks it was well worth it, it took a little bit to get running, the idle was pretty easy, a nice 1100-1200rpms. It sounds pretty interesting too, especially when vtec kicks in.
Source
__________________
¦Ð¦É¦M-|-Z¦™
DIY: Quad Throttle Body Rocket Fuel Nitrous
Learn: SOHC vs DOHC
I drive the only Lancer R in the world.
The only true cheap way to lose pounds off your ride, is to put your driver on a diet.
Offline
Old Dec 21, 2006, 09:41 PM   #2
Daily Activity: 0%
This is not quiet DIY, I think the DIY should be removed... I always mess up subject titles.
__________________
¦Ð¦É¦M-|-Z¦™
Learn: SOHC vs DOHC
Offline
Old Dec 21, 2006, 09:51 PM   #3
Personal Sales Rating: (18)
fromWRXtoEVO's Avatar
Drives: 12STI,11' MB C300 sport,05 Evo 8 MR, 97 Corolla,05 Vespa,78' vespa P200E
Points: 22,408, Level: 93
Points: 22,408, Level: 93 Points: 22,408, Level: 93 Points: 22,408, Level: 93
Daily Activity: 7.0%
Daily Activity: 7.0% Daily Activity: 7.0% Daily Activity: 7.0%
Good job
__________________
Just here loyal to my Evo community as always. In business since 2004, owner of 4 Evos and counting
Offline
Old Dec 21, 2006, 09:52 PM   #4
Daily Activity: 0%
This is in the lancer forum... For NA engines. The project doesn't take that long, but it's a lot longer than just slapping a GT35R on. No worries pimp, the gains are smaller, but race NA engines just has that feel that turbos can never match.
__________________
¦Ð¦É¦M-|-Z¦™
Learn: SOHC vs DOHC
Offline
Old Dec 22, 2006, 06:42 AM   #5
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: 2004 Ford Explorer
Points: 45,436, Level: 100
Points: 45,436, Level: 100 Points: 45,436, Level: 100 Points: 45,436, Level: 100
Daily Activity: 0%
DJ zero 1980 Blacksheepdj
Wow. The man's a damn genius. If I had the time/money...
__________________
Currently playing:
PS3 - blacksheepdj - Journey
PS Vita - blacksheepdj - Uncharted: Golden Abyss
XBL - DJ zero 1980 - Gears of War 3
Check out the Evom store!
Offline
Old Dec 22, 2006, 07:08 AM   #6
Personal Sales Rating: (10)
SLVROZ_03's Avatar
Drives: '03 OZ Rally
Points: 10,686, Level: 68
Points: 10,686, Level: 68 Points: 10,686, Level: 68 Points: 10,686, Level: 68
Daily Activity: 0%
Okay, I'm confused... Was this supposed to be used on a Lancer? or were you just showing us how easy it is to set it up on a car in general? DIY ITB on Honda's just isn't new, but still a congrats are in order...
__________________
Mission accomplished! Got the garage, and now it's time to play!!!
Offline
Old Dec 22, 2006, 08:44 AM   #7
Daily Activity: 0%
Quote:
Just a general guide.
__________________
Currently playing:
Offline
Old Dec 22, 2006, 09:09 PM   #8
Personal Sales Rating: (8)
Drives: Mitsubishi Mirage
Points: 7,349, Level: 56
Points: 7,349, Level: 56 Points: 7,349, Level: 56 Points: 7,349, Level: 56
Daily Activity: 0%
Yea but we need stand-alone too.
Offline
Old Dec 22, 2006, 10:44 PM   #9
Daily Activity: 0%
Yup, or some piggy tricks maybe?...
__________________
¦Ð¦É¦M-|-Z¦™
Learn: SOHC vs DOHC
Offline
Old Dec 22, 2006, 10:58 PM   #10
Personal Sales Rating: (5)
555R's Avatar
Drives: 2006 Mitsubishi Lancer Evolution MR,2005 AMG Mercedes 500 CLK, 1993 Honda Civic Track Monster(SOLD)
Points: 8,176, Level: 61
Points: 8,176, Level: 61 Points: 8,176, Level: 61 Points: 8,176, Level: 61
Daily Activity: 0%
Send a message via AIM to 555R
you coulda made it a bit easier if u bought my Honda 929 throttles
the TPS plugs right in
and the voltage range is the same for any other honda acura
__________________
But what do I know.....
I'm just the 800 pound gorilla in the room!
Offline
Old Dec 23, 2006, 10:26 AM   #11
Personal Sales Rating: (2)
DemisedGabe's Avatar
Drives: 2003 Lancer OZ Rally
Points: 5,973, Level: 50
Points: 5,973, Level: 50 Points: 5,973, Level: 50 Points: 5,973, Level: 50
Daily Activity: 0.5%
Daily Activity: 0.5% Daily Activity: 0.5% Daily Activity: 0.5%
Send a message via AIM to DemisedGabe
interesting.
__________________
myspace.com/demisedgabe5
Items for sale:
Stock Cam
Stock Fuel Rail
Tama 5 x 14 Snare drum
Stock Intake Manifold
stock grill
Offline
Old May 17, 2007, 01:58 PM   #12
Personal Sales Rating: (6)
SnapDragun's Avatar
Drives: 2003 Mitsubishi Lancer Oz Rally Edt.
Points: 176, Level: 3
Points: 176, Level: 3 Points: 176, Level: 3 Points: 176, Level: 3
Daily Activity: 0%
Send a message via AIM to SnapDragun Send a message via Yahoo to SnapDragun
I know this is like grave digging to ressurrect a thread but did anyone ever try this on a lancer?
__________________
Quote:
...WHOA slow down man it's raining........Thats not rain man, that is God drooling cuz he's so impressed with my awesome driving...
T.D.L.R
Team Draguns Lair Racing
10 Seconds Is All I Need To Make You Bleed The Green Seed
WTB: Nothing
Offline
Old May 17, 2007, 02:09 PM   #13
Personal Sales Rating: (7)
1999 Mazda Miata
My Garage
ambystom01's Avatar
Drives: CaliMR to the VD clinic
Points: 17,144, Level: 83
Points: 17,144, Level: 83 Points: 17,144, Level: 83 Points: 17,144, Level: 83
Daily Activity: 99.8%
Daily Activity: 99.8% Daily Activity: 99.8% Daily Activity: 99.8%
Nope otherwise you'd think there would be a thread on it.
__________________
TBR FL Squadron: Green Ranger
Quote:
Originally Posted by 02lancerguy View Post
Amby walks into a bar...instant bar fight ensues.
Offline
Old May 17, 2007, 02:20 PM   #14
DRFTKNGG's Avatar
Drives: an evo addicted to METH!
Points: 6,558, Level: 53
Points: 6,558, Level: 53 Points: 6,558, Level: 53 Points: 6,558, Level: 53
Daily Activity: 0%
I bet they sound awsome WOT!
Offline
Old May 18, 2007, 06:22 AM   #15
blaze_125's Avatar
Drives: Yellow OZ
Points: 14,566, Level: 78
Points: 14,566, Level: 78 Points: 14,566, Level: 78 Points: 14,566, Level: 78
Daily Activity: 0%
Quote:
RPW at some point was supposed to come out with something similar, then they stepped down to a dual TB setup. We have yet to see someone with a functional setup.
What worries me with the setup described here, is the lack of air filters.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
bodie, bodies, body, calgary, diy, honda, individual, itb, itbs, set, sohc, spacer, subaru, throttle, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
