Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 19, 2006, 11:27 AM   #76
Personal Sales Rating: (12)
N1te's Avatar
Drives: Lancer
Send a message via AIM to N1te
Just ordered this. I really hope it works.
__________________
Washington DC Area Lancers -DCEvoClub-
"dang, wonder what i can do now to keep this turbo thing cheap for him. i am in maine and fast and the furious is just hitting so everyone wants a bov"
Want To Buy: NSC Engine Dampener 60 Bucks!
Offline
Old Apr 19, 2006, 12:05 PM   #77
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
It does
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Apr 19, 2006, 01:47 PM   #78
Personal Sales Rating: (1)
airlinevomitbag's Avatar
Drives: '07 Ranger/ '01 Aprilia Falco '03 Taurus No Mitsu :(
Send a message via AIM to airlinevomitbag Send a message via Yahoo to airlinevomitbag
I have been using and abusing seafoam for years. The thing with the oil and needing to change it after you use it is not really true. The seafoam does its thing and burns off. I pour a can (the whole thing) in my MX6's new oil everytime I change it and here and there when it smokes. If you are flushing the engine I'd change the oil but if you are just doing some preventative mainteance screw it) Its the only thing that keeps it from smoking (bad valve seals) and probably the only thing that keeps it running, she is pretty much wore out.
__________________
Thats impossible, Rhonda! How can you sleep when you're high on crack!?
Offline
Old Apr 20, 2006, 08:30 AM   #79
Kid Lancer 7's Avatar
Drives: '03 Lancer es - '01 mirage - 2008 Ford Edge
Send a message via AIM to Kid Lancer 7
this pic is better.. so i'll illustrate on it
again... for those that arent sure where to pour it into the vaccum hose.. this pic's 4 u!
after you poured 1/3 into the gas tank and 1/3 into the oil. put the other 1/3 down that little hose.. while the car is off! u might have to repeat the process on the vaccum hose until the rest of the 1/3 is done!
__________________
THE LANCER SAVED MITSU!!
MY REGISTRYPics!
Offline
Old Apr 20, 2006, 09:10 AM   #80
Personal Sales Rating: (19)
arpad's Avatar
Drives: in the slow lane
i thought you were supposed to let the hose suck it in while you're revving the engine?
Offline
Old Apr 20, 2006, 10:00 AM   #81
Quote:
if u have someone to help you .. suure! but if not... its the same principle
__________________
MY REGISTRYPics!
Offline
Old Apr 20, 2006, 12:07 PM   #82
arpad's Avatar
It just seems to me that if you pour it in when the engine is off, it'll flood the manifold and it'll be hard to start back up. Am I wrong?
Offline
Old Apr 20, 2006, 12:12 PM   #83
blaze_125's Avatar
Drives: Yellow OZ
That's why you put it in while the engine is running.
__________________
Offline
Old Apr 20, 2006, 12:14 PM   #84
arpad's Avatar
Oh, sorry, I must have misread your post... I thought it said that you have to pour it in the vacuum hose when the car is off...
Offline
Old Apr 20, 2006, 02:12 PM   #85
... yeah i did it with the car off.. and then turned the car on......i didnt have problems starting up.... but yes it will stutter but u just give it gas and its all good.. the black smoke come out the back... if you pull that hose off while the car is on ur car will shut OFF. and it wont start with it off
__________________
MY REGISTRYPics!
Offline
Old Apr 20, 2006, 02:15 PM   #86
blaze_125's Avatar
Drives: Yellow OZ
Quote:
Originally Posted by Kid Lancer 7
... yeah i did it with the car off.. and then turned the car on......i didnt have problems starting up.... but yes it will stutter but u just give it gas and its all good.. the black smoke come out the back... to me either way is the same
The only thing that scares me about your method is Hydro-Lock. Don't get me wrong... you're method is probably just as good, but hydro-lock is something I wouldn't want to risk.
On top of that, if you use SeaFoam while the engine is running, SeaFoam will be spreaded properly through the block. If you use it while the engine is off, the liquid will sit on top of the valve until they open and do a single cleaning process as opposed to multipe times if the engine is running.
__________________
Offline
Old Apr 20, 2006, 02:18 PM   #87
so then that means you're pullin a different hose? cus when u pull that one in the pic the car will shut off
__________________
MY REGISTRYPics!
Offline
Old Apr 20, 2006, 02:21 PM   #88
blaze_125's Avatar
Drives: Yellow OZ
When you pull it, you have to squeeze it in order to seal it.
Then take it to the SeaFoam cup and let it suck in the product. The engine will shut off if it sucks in too much air. When you open the hose near the SeaFoam source, what's comming into the engine is now a mixture of Air/Liquid and the engine keeps running(unless there is still too much air comming in). I had to restart the car 3 times when I used that hose.
__________________
Offline
Old Apr 20, 2006, 03:24 PM   #89
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
Where are you guys actually getting this stuff, I checked Canadian Tire and they had no idea what I was talking about.
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Offline
Old Apr 20, 2006, 03:28 PM   #90
jchangsta2six's Avatar
Drives: 03 Lancer
Send a message via AIM to jchangsta2six
if u go on their site .. they have a few places you can buy it ... i know advance auto parts is one place ...
__________________
Offline
Tags
2004, booster, brake, clean, cleaner, cylinder, engine, explorer, form, injector, needed, sea, seafoam, seafoaming, severe, sludge
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
