kamikaze header install
If i get the kamikaze header for my car... will i have to pull the engine out just to put it on or no? If i do have to remove the engine then i will not get the header!
Please help.
Please help.
No you don't. I don't know of ANY motor where you have to pull the block to install a header. Not even Corvettes or anything of the sort. You should be able to set it right in without any problems.
Header and downpipe are a breeze to install. No need to pull out the engine.
1. Disconnect the o2 sensor
2. Take off heat shield
3. Take off downpipe
4. Take off header
5. Take off o2 sensor from stocky
6. Put o2 sensor on new header
7. Put header on
8. Put downpipe and don't forget the hangers
9. Connect o2 sensor
Enjoy
4. Take off header
7. Put header on
Enjoy
4. Take off header
7. Put header on
Enjoy
4. Take off header
7. Put header on
Enjoy
basically.
