Looking to Tune my 2010 Lancer ES
Hey guys and gals, just joined the site and been looking through all the forums about tuning my Lancer. I would just like to know what you think would be best for my car. All I have on it right now is a Magnaflow glass pack exhaust, rims & tires, and a stereo system.
I have been told to start off with a cool-air intake, and maybe some gear ratio changes. (seems to hold the gears forever).
Let me know what you think!
Dan0867 (Aug 11, 2023)
Intake is a good place to start. There are a few options out there from different companies so do your research. I have an K&N Typhoon intake and I love it. I kept the factory snorkel on it so it takes the coldest air possible into your engine.
After that you should look into Headers, ECU Reflash, and maybe a HI-flow cat. Stick with the gears you have stock for now, but I also haven't looked into changing them at all so I don't know what would be good for our cars
I have a 2.0 and it works! I installed it myself with 0 problems. Plus I believe the engine bay is almost exactly the same so even if you did have a 2.4 gts you could still go with the k&n typhoon SRI. Look no further haha
When you mentioned changing gear ratios there is a bit of a problem if you car is automatic. The problem is the CVT tranny that is designed for saving gas and that's it. In that case there technically are no "gears" it is just a belt.
for intakes, I'd recommend the Takeda sri, as its a good design. as for tuning, RoadRace motorsports has a piggyback that is pretty straight forward and works well with higher octane.
Alright so I've already gotten an Injen CAI and it works perfectly (installation was a pain though), although I've been told to not mod performance wise because of my weak transmission, which is the automatic CVT. So until I can afford an Evo it looks like its just cosmetics for me! Thanks for your input guys I appreciate it
add some pics!
I just installed my injen cai as well. I love it. They sell those small plastic clips you prob broke from the bumper at auto zone. like 5 bucks for 12 of em. First thing i got was a sprint booster and i love that as well. larger TB , then rpw 4-2-1 headers, magna flow high flow catback, finally a works tune flash and i think that'd be good.
add some pics!
Okay azou, you basically have done everything I want to do with my lancer. I have the SRI and cat back exhaust. My question to you is how much extra performance will the header get me as well as the tune? I've heard lots of info about the tune so I really want that. And the 4-2-1 header is what I want to do too but I have the pzev 2010 lancer and I'm worried they won't do much if I get a header
Im sorry I shoulda clarified a little more. Those last mods were "up next" mods. So far Its just Injen CAI and sprintbooster.
Youre right about the header with pzev. From what i undestand you have to get the rrm adapter to fit the first cat just behind the header.
When you are saying Typhoon Intake system, are you referring to this?
http://www.knfilters.com/search/prod...rod=69-6546TWR
Reason why I am asking because this is listed for GSR, not for my 2010 ES with 2.0 engine. Just wanted to make sure this would fit onto my car before buying it.
Also what exhaust system would you recommend for 2010 ES? It seems like the options for ES is pretty much limited.
Also for the exhaust it is limited, i just have a catback magnaflow. It's pretty loud and i like the low rumble to it. After adding an intake it did change the sound a little
