Oct 18, 2009, 03:03 AM
Personal Sales Rating: ( 0)
Drives: 2008 Lancer GTS
RRM piggy-back ECU
I am in iraq right now but i went home on leave a month ago and i had ordered some parts and they were waiting on me when I got home. i got a injen axle-back, injen CAI, RRM aluminum crank pully, RRM timing control box, and I also got the RRM Piggy-Back ECU. I installed everything but the piggy back. I could tell a huge difference with everything but only after 3500 RPM and a little off the line. but i have not installed the piggy back yet because you have to splice wires to the ECU and it will VOID EVERY WARRANTY on the the car. also it is not 50 state emission legal. so with that said i am going to have to wait till i get 100,000 miles on the car. kinda lame. i wish there were just plugs and no splicing wires. if anyone has installed it have you taken it to get inspected and what gain did you get out of it?
__________________
[x] Injen SP Series Cold Air Intake
[x] Injen SES Performance Exhaust
[x] RRM Timing Control Box
[x] RRM Aluminum Crank Pully v.2
[x] RRM Piggy-Back ECU (not installed yet)
[x] 35% Window Tint
[x] DIY Red Calipers
[x] Sun and Sound Package
[x] Navigation In-Dash Unit
Offline
Nov 23, 2009, 02:57 AM
Drives: 2009 Lancer DE M/T
Honestly i have not installed a piggyback yet but plan on gettin one, and i wouldnt worry about the void warranty, it wont void everything and the likeness of it messing up your car is slim to none, and i doubt they would even find or know your wires were spliced.
Offline
Nov 30, 2009, 04:22 AM
Drives: Lancer DE, DAKOTA R/T
yesh tht does sound lame. they sould have made a adapter for the thing so you just hook it up.
Offline
Jan 13, 2010, 01:53 AM
Piggyback ecu
Whats up nuzz you ever get around to putting the piggyback in cause if not i will buy it from you
__________________
Fujita SRI
RRM Timing module
RRM V2 Crank pulley
Custom Catback w/Dual Tips
Custom Short shifter
8,000k HID conversion
Debadged Rear
Blacked Out Front Center
Carbon Fuel Door
Carbon Spark Plug Cover
Smoked side markers
18'' GTS Rims
Battery Relocated to trunk
Front and rear strut bars
Floor Stabilizer Bar
Dropped on Tien S Techs
Offline
Jan 22, 2010, 07:11 AM
2008 Mitsubishi Lancer
It would be impossible to make an adapter for this product. It really isn't that hard. Cut a few wires, remove the insulation tips, twist them together, and put a little solder on each part. Tape and mount.
Mine has passed 2 inspections in TX.
When I spoke with my dealership I asked them about the piggy and warranty. They said it wouldn't hurt my warranty unless it was causing the problem. Then in that case I'd just have to take it off and put the wires back to stock. If the issue turned out to be the wiring then they wouldn't allow the warranty to cover that issue. In no way can it hurt your car if you use common sense. The stock maps on it are all within range and won't hurt anything.
Talk to your dealership and let them know where you stand. Most of them are cool and car lovers like us.
Also, my piggy is for sale and can be re-programmed by RRM for $40 if you want a good deal.
__________________
[x]RRM Header
[x]RRM Axle Back Exhaust
[x]RRM Light Aluminum Crank Pulley V2
[x]RRM Short Ram Intake V2
[x]RRM Hood - Evo Extreme
[x]Black Powder Coated Stock Rims
Offline
Jan 23, 2010, 12:12 AM
you got the header for sale? I want it if you do, and as goes for the piggy, if it was ready for my m/t i would get it, dont want to go thru the trouble of sending it to rrm.
__________________
Fujita SRI
RRM Timing module
RRM V2 Crank pulley
Debadged Rear
Carbon Fuel Door
Smoked side markers
18'' GTS Rims
Offline
Jan 25, 2010, 10:53 AM
Back on track
Im just trying to get this thread back on track so i am wondering is whats the best way to go rrm piggyback for 240$ total or pay 419$ and get works flash? I called works and they told me that i would not be able to use my timing control box by rrm, so i would have no use of it, so whats better spend 240$ on piggy and be done with it or spend 419$ for a flash, sell my lil box for 200$ and come out really only spending 219$ for it? I cant decide, i want what ever i can get more hp/tq from
__________________
Fujita SRI
RRM Timing module
RRM V2 Crank pulley
Debadged Rear
Carbon Fuel Door
Smoked side markers
18'' GTS Rims
Offline
Jan 25, 2010, 11:03 AM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
sending it to RRM wouldnt be that much of a hassle plus it would work with your timing module. The works flash is good but has only proven good gains on the 2.4l engine. i think for the 2.0 the gains are minimal and you wouldnt get the full effect at least for 419 bucks. to get the full effect of a works flash you would have to go to their facility and have them do a base line dyno then do a dyno tune.
also with the rrm piggy back any reputable tuner can help you safely tune it for more power (i dont know the extent of what the piggy back can do) but it would be cool to be able to change maps from more fuel efficient to more power when you need it.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Jan 25, 2010, 10:27 PM
Did some thinking and reasearch, piggy is my vote
__________________
Fujita SRI
RRM Timing module
RRM V2 Crank pulley
Debadged Rear
Carbon Fuel Door
Smoked side markers
18'' GTS Rims
Offline
Mar 17, 2010, 01:14 AM
Drives: lancer GTS 2008
Did you feed your lancer with RRM piggy already? 100,000 miles is a lotttt..why dont you sell this to me ;p ?
Seriously, i make 37,000 miles in a year. so for 100000 is at least 3 years. A new version of piggy may be up by then.
__________________
RRM light pulley
Pivot Voltage Stabilizer
Denso 0.4mm Iridium Spark plug
HKS Hi-Power Exhaust
Takeda w/heat shield SRI
Rallyarmour Mudguard
Scangauge II
Offline
Tags
08, back, box, control, diy, ecu, gain, lancer, legal, piggy, piggyback, rrm, timing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
