Oct 6, 2009, 02:25 PM
Personal Sales Rating: ( 12)
Drives: a boostmobile
Need Help With Base Tune
Okay so I've been tunning my car for the past week and it feels like I haven't made any advances. I have the speedcorps mani, 16g turbo with ported 10.5 hs, ported stock o2 housing, 3" dp, 3" hfc, 3" catback, 440cc injectors, 12:1 fmu, walbro 255, bored fuel rail, stock evo intake, intercooler and piping.
This is the tune I currently have and leans out under boost.
tune
Here is the most current log.
log
Any help for a good map to start me off with will be greatly appreciated. I can adjust the timing and such, I just need help with injector latencies and octane fuel maps.
Thanks
Offline
Oct 6, 2009, 03:06 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Why are you still using the fmu?
Offline
Oct 6, 2009, 03:39 PM
I was also going to ask if I still need the fmu with those injectors and stock fpr?
Offline
Oct 6, 2009, 03:57 PM
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
the only thing i tune with is the tatrix cable. i still have my stock fpr as well
Offline
Oct 6, 2009, 04:03 PM
I really need help with this base tune.
If anyone can help that would be great.
Offline
Oct 6, 2009, 05:10 PM
hey john-
send them to my email. those links are whack for me. it takes me to the site but i cant dl it anywhere.
man i gotta get my ftp server up again, then we could all liknk to it and not have to go to 3rd party stuff to upload...
josh
Offline
Oct 6, 2009, 05:25 PM
Email sent...
Offline
Oct 6, 2009, 05:47 PM
Quote:
This is the tune I currently have and doesn't feel right at all.
MAP
Here are some logs that I recorded with different tunes.
10/06/09
10/05/09
Thanks
i say first off lets smooth out both of your maps a little more. after taking a look they kinda loo all over the place in the higher load and rpm values. whats the car acting like?
and did you take out the fmu yet as well? that may have something to do with it acting wierd.
josh
Offline
Oct 6, 2009, 05:58 PM
I'm currently reflashing my phone. I'll txt/call you in a little bit.
Offline
Oct 6, 2009, 06:11 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Were you WOT in either of those logs? The highest TPS% I'm seeing is around 45% or so. I'm not sure if there's no knock because you're not WOT or because the tune is very conservative.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Oct 6, 2009, 06:41 PM
No I haven't done any WOT pulls because it ends up spiking to 15 psi. I'm just waiting for my wastegate spring to come in.
Offline
Oct 6, 2009, 09:35 PM
Updated first post.
I edited my fuel maps and smoothed them out a bit. But now I'm running lean under boost.
Some help please.
Offline
Oct 6, 2009, 10:05 PM
Let me know what happens on your end. My problem is pretty similar: 9psi, running lean under boost, fuel tables are maxed out. Currently using walbro 255, wrx 440cc injectors and stock fpr.
Offline
Oct 6, 2009, 10:34 PM
Quote:
Updated first post.
Some help please.
man u 2 have racked my mind tonite. smooth it out for it to work better and now lean? dang it!
as i mentioned to merc maybe some injector cleaner or seafom to clean out anything that mite be in there. and as i mentioned to john try some crc maf cleaner.
and both of your were running fmu's before the injector swaps correct?
man i need to sleep this one off and come back at it tmw!
Offline
Oct 6, 2009, 11:02 PM
Drives: corn fed turbo lancer
Are you using the stock MAF?
This thread will help (last couple pages) Lean under boost!!
You need adjust your MAF scaling.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
