Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 16, 2009, 01:17 PM   #1
Personal Sales Rating: (0)
Drives: Mitsubishi Eclipse GST 1997
EcuFlash: Rev Limit problem
Heres the situation:
Went to tune the car(Lancer DE 06)
Result were pretty good
But the Rev Limit was crazy
In neutral the car would rev up to the reflashed value(6800rpm)
But when doing the dyno run it would only rev up to stock value(6200)
Then in the final run when we let the car cold down it did rev to 6800rpm
How can i make it rev to 6800 constantly?
I'm going to install a cam in the near future thats why i want to rise it
Heres the dyno graph
Thanks for your help
Offline
Old Sep 16, 2009, 06:26 PM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
What is your ROM ID? Stationary rev limit is different from rev limit. So you have both the stationary rev limit AND rev limit set to 6800? Letting the engine cool down should have no effect on the rev limit changing.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Sep 16, 2009, 11:03 PM   #3
ROM ID is 88250012
Stationary Rev Limit was the default value(7500)
And the i set the Rev Limit to 6800
I can show you logs where it didn't reached 6800rpm
And then suddenly in the last run it did
Unless the Def was wrong (i just copied it from the 88250013 that is around here)
I don't what could it be
Offline
Tags
1997, 1998, eclipse, lancer, limit, limiter, mitsubishi, problem, rev, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
