Sep 12, 2009, 12:06 AM
Personal Sales Rating: ( 0)
Drives: 2003 Mitsubishi Lancer ES
Definition Problems with ECUFlash
First time ECUFlash user here naturally. I updated my ECUFlash with all the definitions from the master definition list. Dumped the master list into the rommetadata/lancer folder. When I open up ECUFlash, I select the 2001-2005 Mitsubishi 3rd Gen/EVO7-8 option (I don't see any lancer options or what not). ECUFlash reads my Rom no worries and brings up all the data. It loads up the Definition for an 03 OZ Rally with a manual transmission. One thing though, my Lancer is an 03 ES with an Auto Transmission. Any ideas? I've browsed through dozens of pages regarding ECUFlash and didn't get where I needed to go.
Offline
Sep 12, 2009, 12:13 AM
Personal Sales Rating: ( 13)
Drives: 03 16g lancer es
hmmm im an 03 es and i havent had any problems and it even loaded the right def for me
Online
Sep 12, 2009, 12:15 AM
heres a pic of what mines looks like
Online
Sep 12, 2009, 01:32 AM
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Same here 03 es but im manual mine looks just like link62. Kinda confused on what your asking? All the data comes up and correct? Are you just worried because the rom info reads manual trans?
__________________
16G Turbo build: Build completed tuning time
Offline
Sep 12, 2009, 02:27 AM
Pretty much, my computer connects to the ECU like normal (Or what I think is normal), but when it pulls up the ROM, all the Parameters come up, except everything is blank. I can't edit nor look up anything. When I check the ROM info, it pretty much says it loaded the 03 OZ MT Definition. It's weird. EVOScan works perfectly fine.
I'll post up a screenshot in the morning
Offline
Sep 12, 2009, 02:46 AM
Ok I see what you mean now, strange...
__________________
Offline
Sep 12, 2009, 02:55 AM
Maybe something went wrong during the install? Am I supposed to delete or move anything after I upload all the definitions? I'm running the newest version of ECUFlash (1.49 I think) and I restarted the program too after I transferred the definitions.
Offline
Sep 12, 2009, 03:15 AM
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
sounds like you still need your rom defined, wait for a bit cause you'll get a bite from someone who will define it for you soon. Im sure senate will be more than happy to help. After all, he is the master.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Sep 12, 2009, 07:45 AM
Quote:
why would it need to be defiend still since im the exact same as him an 03 es auto and its works for me, so its not that even in the pic on the left it says 03 auto
Online
Sep 12, 2009, 08:37 AM
Personal Sales Rating: ( 1)
Drives: 02 mitsubishi lancer es
your car is using the same xml defs from the lancer oz if you open the xml file that is 81870015.xml you can change the area at the top that says your car name and stuff, also if everything is greyed out you are in beginner mode you need to go into the options and change to developer mode if its still all greyed out your rom is not properly identified...
__________________
2002 mitsubishi lancer ES
[x] Lancer evolution 8 ECU 94170015.bin
[x] Mitsubishi Eclipse 501 MAF
[x] K5M422F6ND w/ Lancer differential
[x] 4g64
[x] exedy clutch kit
Offline
Sep 12, 2009, 09:00 AM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Can you post a screenshot just like link62 did so I can see what your ROM ID comes up as? Or send me a copy of your .hex ROM file (my forum name at gmail dot com). Also do what darkmitsu stated - go to File > Options > User Level and change it to "Developer".
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Sep 12, 2009, 12:01 PM
Quote:
You can be in the exact same car and have a different rom id. I didnt think about the developer level though. Its probably just that.
__________________
Offline
Sep 12, 2009, 01:40 PM
I tried setting the options to developer mode... No luck
Offline
Sep 12, 2009, 04:50 PM
Your ROM is not being correctly identified in EcuFlash. It's defaulting to 81900006. You need to send me a copy of your ROM if you want to be able to use EcuFlash.
__________________
Offline
Sep 12, 2009, 06:43 PM
So pretty much e-mail you the hex file, right?
Offline
Tags
1998, 4g64, definitions, eclipse, ecu, ecuflash, flash, grayed, mac, option, osx, out, parameters, read, work, xml  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
