Sep 7, 2009, 10:46 AM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Timing Map Explanation?
So I'm trying to tune my car, myself, and get everything worked out correctly. I'm curious, what does changing the timing values do? This is for a turbo lancer btw.
Offline
Sep 7, 2009, 10:47 AM
Personal Sales Rating: ( 3)
Drives: 2003 Evolution VIII
if u dont understand that then u should probably pay someone to tune it for u
Offline
Sep 7, 2009, 11:44 AM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Timing refers to the spark plug firing. The lower the number the closer to TDC the plug will fire. As the engine spins faster, the timing needs to be advanced so the plug fires sooner so it can burn the a/f mixture thoroughly before the exhaust valve opens
__________________
16G Turbo build: Build completed tuning time
Offline
Sep 7, 2009, 11:56 AM
Quote:
Well I understand it to a point but I want more information. If I get someone to do everything for me, then what do I learn?
Offline
Sep 7, 2009, 11:58 AM
Quote:
Alright I already knew/understood that, I guess I should have rephrased my question. If I pull timing, that will basically richen the mixture?
Offline
Sep 7, 2009, 12:09 PM
Not quite sure how that works yet havent actually done any tuning yet as I am still waiting on some parts for my build lol. I think it does change the a/f but not sure how much and which way
__________________
Offline
Sep 7, 2009, 02:49 PM
So I've been doing a little research... Is it true that reducing time will help reduce knock? I'm having high counts right now and need to get this worked out soon.
Offline
Sep 7, 2009, 03:27 PM
Personal Sales Rating: ( 11)
Drives: 1955 VDub Turbo <best 9.97@132, 1956 VDub <0-60MPH eventually, 03 EVO OCHO
Quote:
Timing has nothing to do with AFRs....
Tuning timing is the most dificult part of tuning and is where all significant power will be made. You will only do it properly on a dyno. You should get some tuning books or take a course...
Offline
Sep 7, 2009, 03:29 PM
yes or give her gas. it all depend on alot of factors...
BTW. What are you using to tune the lancer
Offline
Sep 7, 2009, 04:15 PM
Personal Sales Rating: ( 0)
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Do you have any reccomendations on tuning books by chance?
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Offline
Sep 7, 2009, 04:37 PM
Quote:
start with this. 1.How to Tune and Modify Engine Management Systems
also.
2.Building & Tuning High-Performance Electronic Fuel Injection ( by the founder of EFI101 school)
3.Engine Management: Advanced Tuning
Offline
Sep 7, 2009, 04:48 PM
also.
Sweet thank you very much!
__________________
Offline
Sep 7, 2009, 05:34 PM
EcuFlash/Evoscan.
Offline
Sep 7, 2009, 07:47 PM
Exactly right, if you look at your logs you will see a reduction in timing with or right after a knock occurs. This is the ecu reducing the timing to get rid of the knock.
__________________
Offline
Sep 7, 2009, 07:49 PM
So is there a certain area to lower timing to start? like if I make it all lower then just work my way up will that be ok?
Offline
Tags
build, charles, civic, evo, explanation, lake, map, maps, pull, quoting, retarded, tdc, timing, tune, tuning, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
