Aug 30, 2009, 05:05 PM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Good Base Map For Me?
Ok ecuflash guru's, this is my very first attempt at changing anything in ecuflash. My 03 es will be turbo'd within the next 2 months and so I wanna make sure I am comfortable with tuning when the time comes so here is my stock fuel maps (TOP) and my altered fuel maps(BOTTOM), I will be running 440 injectors and rescaled my injectors to 412. I found This for the stock latency values of the 440's but it only shows 5 values and ecuflash gives me 7 to define so how do I adjust these? I have not rescaled the timing maps yet and dont know if I should or wait until after I datalog some
I want a good base map to start with so any advice on changes pease let me know!!!! As I stated this is my first attempt so feel free to give me any tips thanks
__________________
16G Turbo build: Build completed tuning time
Offline
Aug 30, 2009, 07:23 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Aug 30, 2009, 09:10 PM
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
Quote:
Originally Posted by senate6268
^^+1 that help me with my latencies!
Offline
Aug 31, 2009, 02:51 AM
Yes thank you senate I just read through the sticky "How to tune your evo" in the evo tuning forums today and he mentions the fuel trims in regards to latencys as well. Ok so how about my load scaling and the afr values I put in as a start, do they look conservative? Should I do any leaning out yet? Or maybe just start with this and log to see what the next step is?
__________________
Offline
Aug 31, 2009, 05:17 PM
Quote:
Start here and datalog. On a side note, there probably isn't a need to have two running threads that are both now focusing on your tune.
__________________
Offline
Aug 31, 2009, 05:30 PM
True this one really isnt needed wasnt sure if I was going to get much help on my build thread but I was wrong lol
__________________
Offline
Aug 31, 2009, 05:35 PM
Thread no longer needed thank you!!!!!!!
__________________
Offline
Sep 3, 2009, 12:44 AM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
So as not to pollute the rest of the forum, does anyone have a base map, I somehow lost mine, and my tune is completely f**ked up right now...
Offline
Sep 3, 2009, 11:30 AM
Personal Sales Rating: ( 1)
Drives: 02 Lancer ES
i have mine but, our ecu id is different. it might brick your ecu.
EDIT: pm sent thunderoz
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Evo Style Grille v4.0
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]NGK Iridium plugs
[X]4g93 Mani Stage 2.5
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]15" Konig Heliums
[X]EcuFlash
[X]Slotted n Drilled rotors
[X]501 MAF (not installed)
[X]Shorty Rear Bumper
[ ]///RRM TB
[ ]Progress Rear Anti Sway Bar
[ ]///RRM RalliSpec X bar
[ ]///RRM Tie Bar
[ ]Project X
Offline
Sep 3, 2009, 12:57 PM
Thanks, I would just copy values anyway...
Offline
Sep 3, 2009, 02:21 PM
Quote:
u looking for the base oz map? i can send u mine if u need it. dont think theres any difference in ecu's from 02 to 03 lancer oz's.
josh
Offline
Sep 4, 2009, 01:24 PM
Ok I got it... Now I just have to get this tune down...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
