Aug 8, 2009, 06:10 PM
Personal Sales Rating: ( 0)
Drives: 2005 Lancer ES
trouble with 1.3 tactrix cable
i can pull my rom with no problem but i can not put anything on ecu from ecuflash . ecuflash keeps giving like a error and i can hear the ecu click . so if anyone has any advice im open for suggestions.
Offline
Aug 8, 2009, 06:23 PM
[19:16:27.000] sending init sequence 1 (0003)
[19:16:28.031] got 0x05 response
[19:16:28.031] sending init sequence 2
[19:16:28.046] got 0x1B response
[19:16:28.046] sending init sequence 3
[19:16:28.421] entering bootloader
[19:16:28.437] sending kernel size (4420)
[19:16:28.453] sending kernel load address (0xFFFF7000)
[19:16:28.453] uploading kernel
[19:16:29.171] verifying kernel checksum response
[19:16:29.171] kernel valid
[19:16:29.390] kernel get version
[19:16:29.406] rkrv: preamble 1 error
[19:16:29.421] reading kernel comm buffer size
[19:16:29.625] reading kernel flash buffer size
[19:16:29.843] interface close
That is the log from ecuflash
Offline
Aug 8, 2009, 06:25 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
What version of EcuFlash are you using? What is your ROM ID? If you can read your ROM then you should be able to flash your ROM as well.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Aug 8, 2009, 08:15 PM
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Not trying to insult you or anything but you have the cable with the bootstrap correct? I think there is one cable with just the obd plug for logging and the other with the white connector as well needed to flash.
__________________
16G Turbo build: Build completed tuning time
Offline
Aug 9, 2009, 07:12 AM
i had the version before 1.42 and i have went to 1.42 as of this morning and i have the 1.3 cable with both connectors.
Offline
Aug 10, 2009, 06:46 PM
still having the same problem rom id is 86640007
Offline
Aug 12, 2009, 11:17 PM
Does your rom you pull look fine in terms of numbers where they should be? or do they look jumbled?
__________________
Offline
Aug 17, 2009, 04:15 PM
Personal Sales Rating: ( 1)
Drives: 02 Lancer ES
EDIT: problem fixed
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Evo Style Grille v4.0
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]NGK Iridium plugs
[X]4g93 Mani Stage 2.5
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]15" Konig Heliums
[X]EcuFlash
[X]Slotted n Drilled rotors
[X]501 MAF (not installed)
[X]Shorty Rear Bumper
[ ]///RRM TB
[ ]Progress Rear Anti Sway Bar
[ ]///RRM RalliSpec X bar
[ ]///RRM Tie Bar
[ ]Project X
Reason: problem fixed
Offline
Aug 18, 2009, 08:23 PM
still having the same problem senate fixed it but still having reflash problem
Offline
Aug 18, 2009, 08:41 PM
maybe you have the same problem as i do.
make sure you have OEM ecu..
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Aug 19, 2009, 05:28 PM
how would i find out??? what did you do?
Offline
Aug 19, 2009, 06:38 PM
well mines pretty straightforward.. i bought this flashed ecu and installed it..
then i realized that i have the flashed ecu, installed the oe one, then it worked.
edit: try this
maybe your ecu is locked..
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Aug 19, 2009, 07:39 PM
Quote:
Originally Posted by ClixT
try this
Definitely worth a try. I'm pretty sure this is meant for ECUs that are locked due to licensing (EcuTek and other flashers do this).
Thinking back I just realized that I was getting this same error when trying to flash my Evo ECU for the first time. I downgraded to EcuFlash v1.29a and all was well. Might want to give that a try, as well.
__________________
Offline
Aug 19, 2009, 09:58 PM
anyway i can get v 1,29a?
Offline
Aug 19, 2009, 11:56 PM
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]EcuFlash
[ ]///RRM TB
[ ]///RRM Tie Bar
[ ]Project X
Offline
Tags
13, 1500, cable, communicate, ecu, ecuflash, error, evo, obddodge, preamble, problem, ram, rkrv, tactrix, unlocker  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
