Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 31, 2009, 09:35 AM   #1
Personal Sales Rating: (2)
2002 Mitsubishi Lancer
*02Lancer*'s Avatar
Drives: 02 lancer oz 74/76/79 Corvettes
Need help with ecu flash.
I just purchased the taxtrix 2.0 cable and connecter set. I downloaded this c:\program files\openecu\ecuflash\ro...ubishi\lance r and i downloaded the top one. I then went on here and downloaded the definition files into the correct location. So i went out and connected the cable to the car and then to the labtop and connected. It did connect it under rom info says my year and trans my case ID and my internal ID whitch is 98720010. but when i go to click on anything else is just say's The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again. and that's all i can do. is look at my Rom info. and the immobilizer What am i doing wrong? How do i go about loading my rom when not at my car.
__________________
Budget Turbo :P
installed
Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand
16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs
injectors
Offline
Tags
description, ecuflash, invalid, map
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
