Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 6, 2009, 05:14 PM   #1
Personal Sales Rating: (0)
jer301's Avatar
Drives: 2009 Lancer GTS
09 lancer cvt dyno and r and d test from rpw
Has anyone read this yet? I am not farmiliar with RPW, but thought it was an interesting article. Looks like the CVT did better than they expected:
http://www.rpw.com.au/shop/index.php...=272&Itemid=40
Interesting reading! Enjoy!
Offline
Old Jul 7, 2009, 02:27 PM   #2
Personal Sales Rating: (2)
Defcon5Es's Avatar
Drives: 2004 Lancer/2009 Lancer GTS Sun/Sound/Navi Package
I knew Cvt is a good Transmission. Thanks for the insight. 54 views and none of them commenting wow...one more thing why the dyno set to 4wd? and the 4-2-1 headers is going to be perfect for our cars.
Offline
Old Jul 7, 2009, 06:13 PM   #3
MasterAK's Avatar
Drives: 08 Lancer ES MT
I read most of it. But where did the CVT "shine" exactly? It's not like the car gained a lot of power.
Quote:
For the automatic model vehicles, we will be offering the aftermarker auto transmission cooler kits, to reduce heat soak on transmission oil and extend the longevity of the transmission.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Jul 7, 2009, 06:14 PM   #4
jer301's Avatar
Yea, i'm not sure if the 4wd thing matters. Sounds like they are headed in a good direction. It seems they are using the baseline dyno as a starting point for improvement. The company is in Australia though. What would shipping be on parts from there?
Offline
Old Jul 7, 2009, 06:44 PM   #5
jer301's Avatar
Quote:
I must admit i just glanced over the job 4 section about the gear shifter. Not sure why that is even there, other than to advertise some additional parts they are making. I did not want to give the impression the CVT shined or gained alot of power. The link was just for info purposes.
Offline
Old Jul 10, 2009, 07:31 AM   #6
Drives: Mitsubishi Magna 2000
Send a message via ICQ to Mitsiman Send a message via MSN to Mitsiman
The R&D guide is being done for both manual and auto owners. The customer who provided his vehicle happened to have a CVT transmission that was all. The R&D guide was to also show customers (Potential) about all the products we are making for the car and the results of them.
IF anyone has any questions about what we are doing or the results we are getting, feel free to ask away. Always happy to explain the results we get.
Our test car is due in to our shop in the next two weeks, when we will be fitting the balance of the exhaust system, extractors (Both designs) and then doing some retuning. As always results of all three upgrades will be independantly tested.
I am not sure what you are referring to in regards to the dyno being 4wd. Our dyno is a 4wd dyno but we are only using the 2wd portion of it.
And for clarification, all figures being qouted are at the hubs / wheels, not flywheel as stated on the dyno printouts. The reason being our dyno has a calibration option to calculate back to flywheel, but we set it to a calibration factor of 1, so that flywheel and hub figures are identical.
The Cold Air Kit results were surprising but welcome. With the easy access you USA customers have to K&N, the K&N Apollo kits are definitly something you should be checking out.
__________________
Racing Performance Works - Mitsubishi Specialists. Check our website if you want to know more.
Offline
Old Jul 10, 2009, 08:09 AM   #7
jer301's Avatar
I thought everything looked good to me. I read in the report that it was a hub dyno, so I just disregarded the "flywheel" at the bottom of the chart. I also assumed that those figures were wheel/hub HP and not flywheel HP. I will always appreciate valuable data for our vehicles.
Offline
Old Jul 11, 2009, 11:54 AM   #8
2008 Mitsubishi Lancer
evo_soul's Avatar
Drives: Lancer 2008 GTS
In regards to your CVT testing.. if possible i would revert to using a 5 speed manual. The CVT transmission tends to have slight diviations during dyno testing because of the Transmission to Engine lock up and engagement. Alot of factors beyond normal control cause this to happen. Slight variances in temp. Belt slippage may throw things off. The more stresses you put on the transmission the variance you are going to in the results. Especially after a battery of tests on the dyno. Run after run after run. Be sure to monitor your transmission CVT temps as well, and if possible have a dedicated fan specifically for your CVT cooler when doing dyno runs. Bolt on upgrades will yield greater power for the engine, but the CVT may start to counter that increased input torque by altering the TQ converter engagement. If you want to talk about these more over the phone or something just send me an email evosoul.com@gmail.com
The best thing you can do is upgrade to a better more stable results with the CVT is to upgrade the transmission fluid such as the fluid that Nippon Oil has. Its designed for performance CVT uses and allows for better transfers of power from engine to CVT since the belts operate more effiecently.
__________________
Current MODs:
XenonDepot 3000k (Low) - Injen CAI - Custom 2.25" Dual Exhaust - Side License Mount - HOS Urban Fr and Rr Lip - Tints: 22% 5% - LED Side Mirror - 18" MSR Style 045 - Scorpion V-LIP - 3 Piece Spoiler - ASW 4-2-1 - KVR CF Brake Pads - KVR J Hook Rotors (Silver)
Next:
XenonDepot HID 3000k (fog) - ASW Engine Dampener
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Offline
Old Aug 11, 2009, 07:54 PM   #9
Update for those interested - our extractor / header packages just arrived so we will be in the next few weeks do the final rounds of testing on the CVT model being header comparison RPW 4-1 V 4-2-1, cat back exhaust and of course the big one, reflahsing factory ecu.
We do plan on eventually doing all the same testing on a manuel model ecu.
We will also be fitting an Auto Transmission Cooler to the CVT Transmission to keep the oil cooler and reduce slippage.
__________________
Offline
Old Aug 11, 2009, 08:13 PM   #10
jer301's Avatar
Sounds good. I did have a question for you in regards to the CVT tranny:
You mentioned on the page you had to find the right gearing combo (i assume you were in sport mode) for the dyno run. I already know from an incident on the track that the transmission will switch to auto mode if you go above 6.5K (don't know how high i got, just know i was above it) and typically our tracks are small so we are usually in 1st or 2nd gear. I am currently runnng a larger track (up to 4th gear) My question is do you remember what gearing/rpm combo you used? How bad did the belt slippage get during testing? It seems at the last event that my car even in sport mode on occasion after my 3rd or 4th run would bogg down as everyone says. This was the first time it happened but like i said, bigger faster track. Just curious.
Offline
Old Aug 11, 2009, 08:21 PM   #11
To be honest I don't remember off the top of my head, but we wern't doing multiple runs every minute. To provide most consistant setup what we did was
Lock vehicle into sports mode and used 4th gear
Did two power runs straight after each other, ignored the first run, and used the 2nd run as our measuring point. This probably allowed the transmission to get to a preset tempature and allowed everything to work consistantly.
We are only just touching the 6500rpm range (The dyno rpm scale is not 100% accurate due to the auto slippage) so we are not having an issue with the transmission trying to change gears
Being aware of how badly auto's can slip on us, we usually give plenty of time between runs to ensure that we get accurate results.
__________________
Offline
Tags
09, 2009, apollo, cooler, cvt, dyno, flywheel, gts, headers, kn, lancer, parts, rpw, transmission, tuning
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
