Gauges from OBDII Port?
First yes i know there is a device called the Greddy infometer that connects to the OBDII port and is very cool.
Now for my question; is it possible to run gauges from the OBDII with a wiring diagram? I would assume not easily as you would need to interpret the signal correctly for the guages, so a second question: Is there some kind of unit that connects to the OBDII connection that can then host gauges (A/F ratio, water temp, etc...)?
I love the look of A-Pillar Guages but dont want to drill through my firewall to run cables.
If its not possible i will most likely end up getting the Greddy Infometer.
__________________
Lancer fan since 1973
