Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 15, 2009, 09:01 PM   #1
Personal Sales Rating: (0)
2005 Mitsubishi Lancer
4mywifeandkids's Avatar
Drives: Mitsubishi Lancer
ROAD///RACE Light Aluminum Crank Pulley
anyone installed this rrm crank pulley yet on there 04-06 lancer es? Is it worth it?
Offline
Old Apr 15, 2009, 10:32 PM   #2
Complink's Avatar
Drives: 03 Lancer OZ 16g
you might pick up a couple hp to the wheels... your probably better off get an underdrive pulley. but if your looking for substanial gains then save and go turbo
Offline
Old Apr 16, 2009, 01:07 PM   #3
do they make an underdrive pulley for the es lancer
Offline
Old Apr 18, 2009, 11:50 AM   #4
Complink's Avatar
i believe rpw does
Offline
Old Apr 20, 2009, 08:53 PM   #5
Drives: 2004 Lancer OZ
Quote:
Where does the underdrive pulley go?
Offline
Old Apr 20, 2009, 10:25 PM   #6
Complink's Avatar
where the crank pulley goes
Offline
Old May 15, 2009, 07:14 PM   #7
2002 Mitsubishi Lancer
My Garage
Drives: 02 Mitsubishi Lancer
i put one on my 02 oz and it works great seems to have given me less drag on the crank and more ponies down. but be careful NOT to bend the crank trigger censor tab taking the old pully out or putting the new one in. IT sucks trust me. NIGHTMARE!!!! 5 weeks in the shop trying to figure out the problem.
Offline
Old Jul 16, 2009, 09:23 PM   #8
imalancerman's Avatar
Drives: 2002 Lancer OZ Rally, 2000 Kawasaki Ninja ZX9R
Send a message via MSN to imalancerman
Hey what was your vehicle doing in regards to the crank trigger problem? I assume your talking about the crank angle sensor tab? And why would you have to go that in depth to change a pulley? Not to dis just curious. All you gotta do is remove the bolt, pull the pulley with a puller, put the new one on, then tighten the bolt down to spec and it'll suck down the pulley flush. Make sure it lines up with the key on the crankshaft though. Oh and as far as getting a pulley, why spend a ton of money on one of those other ones when you can get an ebay pulley for a mirage and it'll work just as well, if not better. I think there are some threads on here that compare the pulleys and found out the ebay one is actually a really good pulley. I bought one and am thoroughly satisfied with it. Just type in mirage pulley on ebay. They're only like 35 shipped. And they are underdrive. All my accessories still work really well.
__________________
Drives a Lancer, nuff said.
Quote:
Originally Posted by rpm_ruffryders View Post
Let those that think outside the box do what REAL TUNERS do best...and thats find new ways to keep the lifestyle/scene that you're in ALIVE.
Online
Old Jul 23, 2009, 08:32 PM   #9
numbers5052006's Avatar
Drives: 02 oz lancer
seems like a rather inexpensive way to get some extra power off the line. i wonder if it would add some power to the car when driving from a dead stop with the a/c on?
Offline
Old Aug 28, 2009, 11:46 PM   #10
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Ok so ya month old thread but what exactly is the difference between a crank pulley and an underdrive pulley? Is the underdrive just a smaller diameter or something?
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Aug 29, 2009, 09:08 AM   #11
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
An aluminum crank pulley has the OEM dimensions and diameter of the stock pulley. But since it is made from aluminum and not steel there is a lower rotational weight. An underdrive pulley increases the diameter of the crank pulley as well as having it made from aluminum. This causes a lower rotational speed on all the accessory belts, in an effort to free up horsepower.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Aug 29, 2009, 11:13 AM   #12
03lances's Avatar
Oh ok good to know cause I bought an underdrive pulley from another member on here and just thought it was another name for crank pulley
__________________
16G Turbo build:
Offline
Tags
02, 09, aluminum, crank, engine, gain, garage, hp, lancer, light, lightened, mitsubishi, oz, pulley, race, underdrive
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
