Apr 7, 2009, 08:50 PM
Personal Sales Rating: ( 0)
Drives: 2003 mitsubishi lancer
Innovative Wideband o2 in replacement of STOCK
Just bought the innovative wideband o2 LC1, and was reading the manual and saw that you can use the Wideband o2 sensor in place of the stock using one of the analog output as a signal into the EFI. anyone done this?
__________________
J Moua
Offline
Apr 7, 2009, 08:57 PM
Personal Sales Rating: ( 12)
Drives: a boostmobile
Seems like it would be easier and cheaper instead of making a new bung.
I would like to know too since I will be buying one soon.
Offline
Apr 10, 2009, 01:51 AM
Personal Sales Rating: ( 19)
Drives: 2003 Lancer OZ Rally
It can be done. You use the analog output one to send the signal to your ecu. You will have to mount the existing o2 sensor somewhere tho because the ecu checks to see if the heater circuit on the o2 sensor is working. So might as well get a new bung installed. About two feet upstream from the pre cat o2 sensor is a nice place as you can run the sensor thru the existing grommet under the car.
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Apr 10, 2009, 08:21 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
I would just get a bung welded into the down pipe to be honest. Why exactly did you want to make it put out the stock style signal?
Offline
Apr 12, 2009, 09:43 PM
eh Lazy... don't want to take the DP off to weld a new bung on it... just want to remove the OEM O2 sensor and plug in the Wideband o2... yeah inkow sad eh...
__________________
J Moua
Offline
Apr 12, 2009, 11:46 PM
Drives: 2003 lancer oz rally
okay, newbie question, but what does a wideband sensor do? i have seen them advertised but don't really know what they are for,
__________________
'03 OZ Rally
2 12" Alpine Type S
Jensen 1300 monoblock
Pioneer mids
Panasonic deck
Projectors
Evo 8 Front and Rear seats
Reupholstered headliner
Black interior
Offline
Apr 13, 2009, 01:22 PM
Personal Sales Rating: ( 1)
Drives: 02 Lancer ES
Quote:
lots of things but mostly a/f ratio.
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Evo Style Grille v4.0
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]NGK Iridium plugs
[X]4g93 Mani Stage 2.5
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]15" Konig Heliums
[X]EcuFlash
[X]Slotted n Drilled rotors
[X]501 MAF (not installed)
[X]Shorty Rear Bumper
[ ]///RRM TB
[ ]Progress Rear Anti Sway Bar
[ ]///RRM RalliSpec X bar
[ ]///RRM Tie Bar
[ ]Project X
Offline
Apr 13, 2009, 02:35 PM
Ok so I'm guessing you want to remove the second O2 that goes into the cat, and remove the cat...
Offline
Apr 13, 2009, 02:36 PM
Quote:
It's like 4 bolts
Offline
Apr 13, 2009, 07:31 PM
yes it is... just don't feel like jacking the car up and crawling underneath... sigh... i guess i'll just DO IT!!!
__________________
J Moua
Offline
Apr 15, 2009, 12:58 PM
Just do it  It only takes a few minutes.
Offline
Apr 15, 2009, 02:14 PM
Personal Sales Rating: ( 13)
Drives: 03 16g lancer es
hes being lazy lol
Online
Apr 15, 2009, 05:17 PM
=) yeah i know... sad thing... my dad's a welder... hahahahha eh guess while i'm under i should pull the motor mounts and fill them as well... I just installed a new clutch and fly and the motor mounts just about sucks...
__________________
J Moua
Offline
Tags
02, alternative, analog, innovative, o2, oxygen, place, precat, put, rear, replace, sensor, signal, stock, wideband  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
