Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 17, 2009, 01:10 AM   #1
Personal Sales Rating: (11)
2002 Mitsubishi Lancer
02-Lancer-Es's Avatar
Drives: Lancer
Question 4G93 IM swap
Ok i just got one of these today off a 4g93 99 Mirage (19bucks at the junkyard )
Only thing i need to know is on the vacuum line for the brake booster it is not where it is on the 4G94 manifold , it is a bit further (6 inchs) would i need to buy a longer vacuum line or is that not the right place where the brake booster vacuum line gos?
__________________
My car
Offline
Old Mar 17, 2009, 11:54 AM   #2
Drives: Lancer
Bump?
__________________
My car
Offline
Old Mar 17, 2009, 01:28 PM   #3
Personal Sales Rating: (4)
b00tl3g93r's Avatar
Drives: 2002 O.Z. Lancer
Send a message via AIM to b00tl3g93r Send a message via MSN to b00tl3g93r
Yeah, you'll need a longer vacuum line, bro.
Offline
Old Mar 18, 2009, 06:04 PM   #4
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
Originally Posted by b00tl3g93r View Post
yeah, you'll need a longer vacuum line, bro.
+1
Offline
Old Mar 18, 2009, 07:18 PM   #5
Personal Sales Rating: (0)
smartidiot2122's Avatar
Drives: lancer oz rally edition
Send a message via AIM to smartidiot2122
yeah mine looks just like that! yeah i brought a snippet of the line to the auto store and got some linking nipple things and more hose. dealing with the front part of the vacuum lines is also confusing as i think were missing a barb so i had to T my pcv valve into the breather hose coming off the intake, intake as in the rubber part the filter is attached too.
__________________
Semi fast:
sri
rrm header
crank pulley
tb bypass mod (lol)
ported 4g93 IM
magnaflow catback
works ss clutchline
Offline
Old Mar 18, 2009, 08:05 PM   #6
Personal Sales Rating: (12)
OZ Rally's Avatar
Drives: a boostmobile
Send a message via AIM to OZ Rally
Yea I had to customize my hoses too. Just port the hell out of it and you should be good.
Once I swap the head then that will be port matched too.
Good luck
__________________
::CHI-BURBS MITSU::
Quote:
Originally Posted by Nubby View Post
If a good forum is like a good college party, then EvoM is at the point when the high school kids showed, drank all the beer, barfed on everything and now the keg is empty and there's no money for another one.
FS: Megan Manifold & Stock Parts
FS: Stock/Aftermarket Parts and Random Mitsu Merch
FS: Meth Kit
FS: All Stock Speakers
Offline
Old Mar 25, 2009, 08:03 PM   #7
Punz247's Avatar
Drives: 03 Lancer Oz RMR Edition
So that bolts up right to the 03's? Whats the benifits from it? and will it give you a CEL?
Offline
Old Apr 6, 2009, 04:05 PM   #8
Personal Sales Rating: (5)
Drives: 2004 lancer
P&P that suker to more HP
Offline
Old Apr 9, 2009, 08:36 PM   #9
Personal Sales Rating: (13)
Green_Bandit's Avatar
Drives: A b00st3d 2002 Lancer OZ
Send a message via AIM to Green_Bandit
IIRC its 99% bolt up. You need 1 shorter bolt instead of all long ones which you probly can get from Mitstu. If I'm wrong please correct me cause I also want to do this mod once I find a junked Mirage...
__________________
Check out my for sale thread! Boost gauges and accessories
4G93 ported powder coated Intake Manifold for sale
Short turbo mod list!!!
[x] Magna Catback
[x] RRM Pully
[x] Enkie J10's with Yokohama Parada Spec 2's
[x] RRM Piggyback
[x] RRM X bar strut bar
[_] RRM rear strut bar
[_] Slotted Rotors and pads
[_]TEIN S-Tech Springs
MyCar
Join Tunerfriends!
RRM Header install/Review
Offline
Old Apr 10, 2009, 01:49 AM   #10
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
need a hose to extend the brake booster. There are two verisons if i remember. One has the 3/8" vac hose near the tb and the other has the barb located towards the right side of the car. As far as bolting to the head, direct fit. Same gasket and all. Like stated above one or two shorter bolts as you will be removing the im support behind the throttle body. It is possible to reroute all vac lines to get rid of the brass fitting junction if you wana but its up to you.... Remember NA setup is gona be different from turbo setup with this mani. Valve cover breather and crankcase breather need to have pcv valves onthem if your boosted. If your na then just tee those both together and attatch to the 3/8" barb on the im...
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Old Apr 14, 2009, 10:24 AM   #11
Punz247's Avatar
So what gains are you looking at? Is it better then our stock IM?
Offline
Old Apr 14, 2009, 05:19 PM   #12
Personal Sales Rating: (2)
*02Lancer*'s Avatar
Drives: 02 lancer oz 74/76/79 Corvettes
As far is i know nobody has ever flowed this intake vs a 4g94 i plan on doing it just havent yet im polishing my 4g93 intake before it goes on. but going by the Characteristics the 4g94 intake will be better on torque because of the long runner's while the 93 has shorter runner better for higher rpm or horsepower also the 4g93 has a larger plenum comparted to the 4g94 so it should be better but no test other then butt dyno's have been done to my knowledge
__________________
Budget Turbo :P
installed
Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand
16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs
injectors
Offline
Old Apr 14, 2009, 05:25 PM   #13
Drives: Lancer
Thanks guys for those of you that helped!!
I still have not even out it on or have finished porting it , just have been to buys .
Did 2 runners all the way opened up , still need other 2 and half of the throttle body side .
Have been really busy with other parts .
Sold Greddy Evo2 catback
Installed
Megan coilovers , new wheel bearings and outer tie rod ends .
Bought but still not on , new front end , Rexpeed type 1 spoiler , Tsx projectors .
So I'm not going to bother with this until i get another catback .
__________________
My car
Offline
Old Apr 14, 2009, 11:33 PM   #14
Personal Sales Rating: (1)
ClixT's Avatar
Drives: 02 Lancer ES
i have a stage 1 p&p 93 IM and its pretty darn good. i just a need tune for better performance.. i might get it ported stage 2.5 = the maximum u can get.
__________________
My Ride
Mods
[X]K&N SRI
[X]///RRM Evo Style Grille v4.0
[X]///RRM Pulley
[X]OBX HF Cat
[X]Greddy Ti-C
[X]NGK Iridium plugs
[X]4g93 Mani Stage 2.5
[X]White-Out HL
[X]Progress Springs
[X]NGK wire set
[X]KYB Struts
[X]Oz Lip
[X]Side Skirt
[X]15" Konig Heliums
[X]EcuFlash
[X]Slotted n Drilled rotors
[X]501 MAF (not installed)
[X]Shorty Rear Bumper
[ ]///RRM TB
[ ]Progress Rear Anti Sway Bar
[ ]///RRM RalliSpec X bar
[ ]///RRM Tie Bar
[ ]Project X
Offline
Old Apr 20, 2009, 09:00 PM   #15
Drives: 2004 Lancer OZ
I have it with the stage 2 P&P and I love it!!!!
And I hooked my piggyback ecu to the extra line
Offline
Tags
4g93, 4g94, case, crank, crankcase, filter, httpwww4g93, im, imnet, installing, lancer, mitsubishi, oz, rally, swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
