Mar 10, 2009, 08:46 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Evoscan Issues
While I finally got EcuFlash to work without any problems on my laptop so I downloaded EvoScan to start tuning.
The problem is, I throw errors when I go to open the program. It is the latest version v2.5 and here is a picture of the message:
EDIT:So I just had to run the program as an administrator so issue fixed, new problem on post 3
Offline
Mar 10, 2009, 10:09 PM
Btw, the laptop it is running on is a 64bit version of Vista Home Premium.
Offline
Mar 22, 2009, 07:56 PM
Ok got that fixed, new issue.
It doesn't seem to be logging anything. It says that it is but I don't see anything happening...
Offline
May 5, 2009, 10:42 AM
Personal Sales Rating: ( 0)
Drives: [2000 Mirage Evolution] [2007 Eclipse GT-6] [2002 Lancer OZ Turbo]
Thunder... did you ever get this working or did you give up? Because i have a great deal of experience with it if you need a hand.
__________________
- 2000 Mitsubishi Mirage Evolution: Project - Evo 8 Swapped Drag Car
- 2007 Mitsubishi Eclipse GT-6: Fastest All Motor 4G
- 2000 Mitsubishi Mirage Sedan: The Daily
- 2002 Mitsubishi Lancer OZ Turbo [Sold]
- 2000 Mitsubishi Mirage Sedan [Traded]
- 2006 Mitsubishi Eclipse GT-5 [Traded]
- 2003 Mitsubishi Evolution [Totaled]
- 1995 Mitsubishi Mirage Coupe [Sold]
- 1997 Mitsubishi Galant ES [Sold]
- 1996 Mitsubishi 3000GT VR-4 [Wrecked]
- 1994 Mitsubishi Galant GS [Traded]
Offline
May 5, 2009, 11:09 AM
Yea I got that part working but I can't log anything...
Offline
May 9, 2009, 02:59 PM
2003 Mitsubishi Lancer
Drives: 2003 Mitsubishi Lancer OZ Rally
i had the exact same problem, except i cant get ecuflash to work for some reason. I re-installed evoscan when I got that error and it ended up working fine. as for ecuflash... i got all the master definition files downloaded and saved to the proper places, but it still says theres no definition for my car. which is bs.
Offline
May 10, 2009, 02:18 AM
Well that error is gone now. EvoScan opens up, runs, and clears codes. It just can't read codes or log for some reason... It say's it has a connection but nothing happens.
EcuFlash on the other hand works perfectly fine.
Offline
May 10, 2009, 10:24 AM
Quote:
Which Ecuflash are you useing...? Becouse you need to be using ver. 1.29 for the lancers. The newer versions i've had trouble getting to work.
What you have set for your baudrate? Mines setting at 15625.
__________________
Offline
May 10, 2009, 11:18 AM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
I used to tell everyone the same thing. I'm currently using v1.41 and haven't had any problems reading, flashing, etc.
Offline
May 10, 2009, 12:52 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
What's the difference with 1.29 and 1.41?
Offline
May 10, 2009, 01:18 PM
Quote:
Lots of bug fixes and support for newer vehicles. There were also changes in how the endian values are interpreted in the metadata files. You can read through the revision history here, if you want:
http://openecu.org/index.php?title=EcuFlash
Offline
May 10, 2009, 01:46 PM
I have both 1.29 and 1.41 on my PC for different cars. It just seems that some versions work better for certain cars then others. Just like I can't read 3G V6 Eclipses on 1.41 but i can on 1.29 for some reason. I'm sure there's a way to get it too work... but straight from the download 1.29 works like a charm on my lancer.
__________________
Offline
May 10, 2009, 06:35 PM
Yea I'm using EcuFlash 1.41 with no issues
How do I check that?
Offline
May 10, 2009, 06:55 PM
It's one of the settings seen here in EvoScan:
Offline
May 10, 2009, 08:11 PM
^ Ya... like he said. lol
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
