trans, diff, transfer case fluids are just like engine oil, they have a service interval, it's 30K
the last 30k I did was on a IX, it had 37k. The diff and transfer fluid was wasted, black, and that's W/O combustion. The trans not much better.
the transfer only holds .63 qts, not very high volume, could lead to problems if not changed often enough.
All automotive fluids turn to acid content with wear/heat/time. This acid eats seals/gaskets and in long term even aluminum. Brake fluid is one of the culprits. Most techs/dealers only change out the reservoir at 30k, a good tech/dealer will flush the entire system and put new. This is accomplished with a vacula. This is critical because all the heat in a brake system is at the calipers. Some race cars they flush the entire system every weekend, the Brembos are a racing caliper. With a full flush every 30K all the brake hydraulics should last the life of the vehicle.
At 60k you might want to consider a PS flush and ABS flush (brake fluid) depending how long you plan to keep the car.
A really good tech will lube hinges, latches and lock cylinders, ebrake adjust. You'll also get any recalls performed. A good inspection and test drive too to note any abnormal issues that are present.
warranty claims can also be denied if services haven't been performed, it doesn't always happen but it can, especially with driveline
you do pay premium, and if you find a good tech you get premium. It's the dealer but more importantly it's the individual tech.
__________________
Mitsubishi dealer tech
Pacific Northwest
the funniest thing about this message is that by the time you realize it doesn't say anything it's too late to stop reading it.
