Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 7, 2009, 07:03 PM   #1
Personal Sales Rating: (0)
Drives: Lancer 08
Gauges that are important!!!
I got a 08 lancer and i do a LOT of driving. my current mods are: lowering springs, shortram intake, crankshaft pulley.
i drive an average of 50 kilometers a day, and i do trips as well crossing the USA border.
i want to keep this car N/A!!!!! i want to get a header, and exhaust and change to a fidanza flywheel.
but i do want to have gauges to monitor this car. which are the most recommended for me? some friends told me this list because the winters are cold and the summers are hot in where i live :
oil temp gauge
water temp
fuel pressure
do those seem about right? i want to put it on a 3 gauge holder on the center dash.
Offline
Old Jan 7, 2009, 07:56 PM   #2
Personal Sales Rating: (1)
nj_08_gts's Avatar
Drives: TB 2008 Lancer GTS, Spec Miata
Send a message via AIM to nj_08_gts
If you have to pick between the two, I'd say oil pressure rather than oil temperature. They're both important, but driving a track car, I care more about oil pressure (or sometimes the lack thereof) than what the temperature is.
__________________
"Speed has never killed anyone - suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Offline
Old Jan 7, 2009, 08:01 PM   #3
TRASHY_GTS's Avatar
Drives: 08 GTS
Oil Pressure
Offline
Old Jan 8, 2009, 11:51 AM   #4
Stuntfly02's Avatar
Drives: Apex Silver 2008 Lancer GTS
Air/Fuel ratio, and Oil pressure would be what I would go with. You can see water temp via the existing display, I'de say oil temp isn't as important unless you spend a lot of time on a track. If you are racing and your oil starts to boil you are in trouble. And if u are having fuel pressure issues you will now it. Shouldn't need a gauge to tell you your engine is running like ****.
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Old Jan 8, 2009, 02:48 PM   #5
Drives: Lancer 08
i will be able to hold 3 gauges
is oil temp more important than water temp because i have a coolant indicator stock?
my main concern about oil temp gauge is that i want to know when i can start driving in winter when i warm up my car. right now i just rely on the coolant but i know that isn't very accurate
Offline
Old Jan 8, 2009, 05:07 PM   #6
nj_08_gts's Avatar
It's not a Formula 1 car...use 0W-20 oil and let the car sit for a minute or two and then drive. Keep the revs low for the first few minutes on the road and you'll be fine
While there is a coolant temperature gauge already, it's more of an idiot light than anything. The only information it really provides you is when the coolant is at a nominal temperature or when the coolant is boiling over.
__________________
- Jeremy Clarkson
Offline
Tags
car, gauges, important
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
