Dec 16, 2008, 03:34 PM
Personal Sales Rating: ( 0)
Drives: 2002 LAncer oz rally turbo
turbo help! noob
hey everyone i am planning on buying a 2002 lancer oz rally with t28 turbo and it is tuned with the apexi safcII. the one thing that has me hesitant about throwin down the money is that it idles high around two grand or so. is this a tuning issue? i have used the apexi neo on my prelude so i am familar with basic operation. any help or point me off to the right thread if this has alredy been posted. i have researched several threads about the piggy back and didnt find anyhting about idle issues.
Offline
Dec 16, 2008, 04:16 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
check if the idle biss screw is open too much, you can lower idle by turning it counter clock wise
Online
Dec 16, 2008, 04:43 PM
ok i'll check that out. I also should have mentioned that the idle will drop down evry once in awhile to where it should be do you still think its the biss? I want to know more about this fuel injection system i know my hondas but this is all new to me can point me where i could do some good research on it?
Offline
Dec 16, 2008, 05:02 PM
so you are going to buy a turbo lancer?
better make sure everything is okay.
how much boost is it running?
Online
Dec 16, 2008, 06:11 PM
yeah i think i'm gonna get it. i'm a certified mechanic so i know my way pretty well. everything looks great beside idle issue. it is running at 5psi. has 470cc injectors. it has a evo front end conversion tein suspensio progress sway bars and strut bar. garret t28 turbo and some other extras like audio and what not. i was just doin some research reading one of the stickys and it said a bov venting to atmosphere will screw it up and give me problems like i have. can you give me some more insite? does that sound like a good reason?
Offline
Dec 16, 2008, 06:14 PM
Personal Sales Rating: ( 7)
Drives: Evolution
i used to tune with the safc II and i know that when you are doing the fuel curves... if you have too much fuel it will idle high... sme thing happens if you have to little fuel.. it will idle around 500-1k... i believe it may just be the initial fuel at idle that may be too high..
Online
Dec 16, 2008, 06:20 PM
ok right now its set at negative ten for idle. IS ther anything i should look out for on this car besides common stuff.
Offline
Dec 16, 2008, 06:54 PM
rx7 injectors?
i am not familiar with SAFC II, but try to lean it out a little on idle until you can idle at 900-1k or so.
I would ditch the SAFC II because I dont think you can control timing with that...
Online
Dec 16, 2008, 07:03 PM
no you cant its simple fuel control. i plan on it but i just want it to run right so i can rest easy on buyin it. i'm gonna fiw the bov than mess with tuning since it was alredy tuned and dyno sheet to prove 205hp at wheels. he said they were ngk injectors
Offline
Dec 16, 2008, 07:21 PM
as for the BOV, you cant VTA because we have a MAF sensor.
im not sure how much knock you get with stock ignition timing at 5 psi, but at 7-8 i was knocking bad without touching the timing and just tuning fuel
Online
Dec 16, 2008, 08:03 PM
Personal Sales Rating: ( 11)
Drives: 2005 Lancer ES/ 92 Talon TSI AWD
check what kind of turbo kit it is. it might be a tsi or custom.
Offline
Dec 16, 2008, 08:31 PM
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Those Rx7 injectors are pretty big for only 5psi. No wonder the SAFC is scaled down at idle RPMs. Also the BOV has to be recirculated or you will have lots of problems.
Offline
Dec 17, 2008, 07:09 AM
ok thanks guys the guy i'm buyin it off of is really cool so he is gonna let me play around with it before i go thru. i'm gonna replace that vta bov with run i can route thru the intake thanks for all your help
Offline
Jan 27, 2009, 10:06 PM
Personal Sales Rating: ( 5)
Drives: 2004 lancer
you should also check for cracks in th exhaust, just by listening to the car drive
Offline
Jan 27, 2009, 10:08 PM
Drives: 2004 lancer
if you get the car, first up grade is a roof vortex, those are nice
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
