Nov 10, 2008, 04:45 PM
Personal Sales Rating: ( 6)
Drives: 2003 Mitsubishi Lancer
MAF Circuit low ..but
I get this MAF circuit low CEL repeatedly, but it's only when the humidity is crazy high. (Right now it's at 100%)
I've tried resetting the ECU, but it comes back (tried today). I've also tried disconnecting and reconnecting the MAF connector to ensure the connection is good. I guess the only other thing to try is to clean the MAF with contact cleaner. Anyone else have this problem?
The only mods I have that might affect this is the RRM short ram and a v1 piggy.
__________________
Quote:
Originally Posted by otter
I don't like the handicapped stalls. I feel like I'm too far away from the door to prevent someone from barging in (this has happened before), since the locks on stalls usually suck. Some 4-5 y.o. kid pushed his way through the lock, saw me, turned around and left, leaving the door hanging open. Couldn't immediately shut it due to my ass being in the middle of birthing something unholy.
As for the urinal rules, most guys put way too much thought into it.
Offline
Nov 10, 2008, 05:59 PM
Personal Sales Rating: ( 9)
Drives: EVO MR
if you need new maf,, pm me i have one sale with really low miles!!
__________________
My car got totalled, Check out the sale item
Custom Turbo Kit Installed!!
July 20, 2007
Lancer - RIP
2009 Evo MR
Offline
Nov 11, 2008, 02:40 PM
Personal Sales Rating: ( 2)
Drives: 2003 Rio Red Lancer ES
Spray it out with some WD-40, its probably just water getting in there.
Offline
Nov 21, 2008, 12:10 AM
Personal Sales Rating: ( 19)
Drives: 2003 Lancer OZ Rally
ONLY USE MAF CLEANER TO CLEAN YOUR MASS AIRFLOW SENSOR!!! The other cleaners can damage the sensor. And please do not try to use WD-40 to clean it... I mean c'mon. Usually a low reading is related to an abnormally low reading from the MAF. Clean it with maf cleaner and it should go away. There is too much resistance it is seeing due to the grime on the sensor probe.
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Nov 21, 2008, 08:39 AM
Personal Sales Rating: ( 1)
Drives: 2002 Lancer OZ
Quote:
Do not do this. WD-40 is a lubricant.
Use MAF cleaner.
Offline
Nov 21, 2008, 08:46 AM
Personal Sales Rating: ( 11)
Drives: 2005 Lancer ES/ 92 Talon TSI AWD
the maf cleaner does wonders and it really works.
Offline
Nov 21, 2008, 10:57 AM
Thanks, i'll be sure to try this
__________________
Offline
Dec 31, 2008, 09:56 AM
I tried the MAF cleaner but no luck thus far. Do I have to reset the ECU for the CEL to go away or something?
__________________
Offline
Jan 27, 2009, 01:49 PM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
Quote:
Use MAF cleaner.
http://www.google.ca/search?hl=en&q=...%3A+wd40&meta=
See 3rd point.
As far as I know... WD40 = Water Displacement 40th attempt
If you have a piggy hooked up, check your connections. Something isn't hooked up properly and is getting bad conductivity when it gets humid.
You can disconnect the battery to reset your ecu, but the CEL will come back. Don't just patch it, fix it.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Apr 6, 2009, 04:04 PM
Personal Sales Rating: ( 5)
Drives: 2004 lancer
WD40 is a no go
Offline
Tags
40, cicruit, circuit, clean, damage, high, lancer, low, maf, mitsubishi, probe, readings, sensor, wd, wd40  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
