Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2008, 01:42 AM   #1
Personal Sales Rating: (0)
Complink's Avatar
Drives: 03 Lancer OZ 16g
Lean under boost!!
ok so i am having a problem with my fuel. i have tried just about every thing except checking the fuel pressure (don't have a gauge). When i first installed my 16g with stock injectors and ecu tuning, it would lean out bad like 17-19 afr at like 4 or 5 psi. then i put in a 12:1 fmu still on stock injectors and my fuel table's maxed out in ecuflash, and it would still come close to 13.5 or 14 afr at around 8 psi. Then i put in wrx 440s, scaled and tuned the trims and removed the reference line on fmu and its even worse. then i reconnected the reference line and tuned my trims and it wasn't much better than the stockers. at this point i was thinking it must be my TRE fuel pump so i got a walbro 255 HP and took off the reference line and its still hitting like 18 afr at wot at prob less than 5 psi. keep in mind my fuel maps in ecuflash are maxed out. I also noticed on a few of my old logs with stocker injectors and fmu my IDC wouldn't go past 64%. So i don't know if maybe my maf is the one to blame. i may have to fiddle with my maf scaling, but not quite sure how to do that.... Any suggestions?
i'd really rather not hook the fmu back up since this potentially causes the fuel pressure to go up to 120+ psi
Offline
Old Oct 28, 2008, 08:41 AM   #2
TouringBubble's Avatar
Drives: IX MR SE
Send a message via AIM to TouringBubble
Can you post a pic of your fuel map? Aslo, are you editing the high or low octane map?
__________________
My Sponsor House Profile | EPM | AMSOIL | GTWorx
"We two souls have shared a cheese sandwich more than twice!"
Offline
Old Oct 28, 2008, 10:17 AM   #3
Complink's Avatar
i'm doing both cuz i remember something about the only one used is the low, so i do both to be sure.
oh and im auto btw.
Offline
Old Oct 28, 2008, 10:19 AM   #4
Complink's Avatar
i will see about getting a log file if that will help
Offline
Old Oct 28, 2008, 10:21 AM   #5
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
Could it be that you're not reacting fast enough, ie. the car hits boost and thus leans out before the extra fuel is added?
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Offline
Old Oct 28, 2008, 10:33 AM   #6
Complink's Avatar
well when im going about 45 and i punch it, my rpms jump to about 4 to 4.5 k and almost instantly its leaned out past 17 or 18 at near 8 psi. so i let off. im auto btw
Offline
Old Oct 28, 2008, 10:36 AM   #7
Complink's Avatar
at wot i won't start getting boost till about 3200rpm... then full boost comes about3.8 to 4k
Offline
Old Oct 28, 2008, 10:40 AM   #8
2007 Subaru Impreza
ambystom01's Avatar
Sounds like a problem going from closed loop to open loop.
__________________
Offline
Old Oct 28, 2008, 11:06 AM   #9
Drives: IX MR SE
Could be Amby ... you could try reducing the values in the Open Loop Throttle table for earlier onset of open loop.
Does the car act like it's lean? Are the plugs reading lean? Everything looks fine with the map ... maybe you have an exhaust leak or a bad sensor?
Yes, logs will help. Please include the stock O2 as well as the WB.
__________________
Offline
Old Oct 28, 2008, 11:48 AM   #10
Complink's Avatar
when its leaner than 16 it hesitates so yeah.
Offline
Old Oct 28, 2008, 11:57 AM   #11
Drives: IX MR SE
What AFR are you reading in closed loop ... steady cruise?
__________________
Offline
Old Oct 28, 2008, 11:59 AM   #12
Complink's Avatar
well the only things i can think of thats wrong are:
1. bad fpr
2. clogged fuel lines
3. ecuflash problem
tommorrow im gonna go pickup a fp tester and see what my pressures look like
is it possible that my ecuflash is not flashing correctly? the rom info is:
lancer oz 5mt 03, ecu idblank), case idblank), internal id: 81900016, flash method: mitsukernel, memory module: sh7052, checksum module: (blank), inherits: 81900006
Offline
Old Oct 28, 2008, 12:00 PM   #13
Complink's Avatar
Quote:
it reads 14.7
Offline
Old Oct 28, 2008, 12:07 PM   #14
Drives: IX MR SE
are the trims in check?
A test would be to slowly roll on to the throttle to 100%. If the issue is in the maps and related to open loop, you'll see the jump in AFR instantly when the crossover occurs.
__________________
Offline
Old Oct 28, 2008, 01:20 PM   #15
Complink's Avatar
ok so i have some logs. and don't mind the trims since it would do the same thing when i had them zeroed and the injectors scaled correctly.
File Type: zip WOT 2nd from cruising 2008-10-28-131428.zip (9.9 KB, 14 views)
Offline
Tags
11v, afr, boost, boosting, car, change, ecuflash, evoscan, lancer, lean, line, map, octane, oz, vacuum
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
