Feb 4, 2009, 05:26 AM
#256
Personal Sales Rating: ( 0)
Drives: IX MR SE
Do you have your maps rescaled to control fuel/timing at 125 load?
That sounds like you're hitting a point in the MAF scaling table where it flattens with increasing airflow. That would cause a rise in AFR if the map values were flat. If your fuel map is in the 10's, then you should be able to ramp it down after 5000 to prevent that lean shift.
No, don't increase fuel pressure above the stock setting. That is a rising rate regulator so it should be fine. To much pressure is bad as you get poor fuel atomization.
Offline
Feb 4, 2009, 01:46 PM
#257
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
yup my timing / fuel maps are rescaled to 130%
i made my MAF scaling similar to yours and that did the trick
because mine used to be a flat 255 from 800hz and above, but now that i changed it to where the value increases, it helped keep my AFR steady  i understand now.
i still have some fine tuning to do though.
Offline
Feb 5, 2009, 10:25 AM
#258
Personal Sales Rating: ( 19)
Drives: 2003 Lancer OZ Rally
so you guys got good results without rescaling the table to hertz? I thought 255 was the max you could go with the tables rescaled by the way...kinda confused here...
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Feb 5, 2009, 11:10 AM
#259
Rescaling it is just another way to view it in Hz instead.
It has no effect, it just helps for logging because it logs in Hz
Touringbubble, did you notice after upshifts during WOT it leans out?
Like from 2nd to 3rd
Offline
Feb 10, 2009, 08:00 AM
#260
Drives: IX MR SE
Quote:
I'm using a different scaling. This was an odd ROM and had different scaling values. 255 is the max value (8-bit) if you take the scaling equation out of the picture.
Yes, I got the results I wanted with the tables I posted. Give it a shot.
4G, I haven't looked in to AFR on shifts as this was an auto car. I do have one 5 speed tune in the works but weather and travel has kept him from logging recently. I'll be sure to look in to it though.
If you are seeing odd occurences on shifts, you can adjust the fuel map in the load/RPM area where the shift takes place. You stay in open loop on a shift, so the changes to the MAF values will cause a shift there. You should be able to adjust the map to correct the issue pretty easily.
Offline
Feb 18, 2009, 01:15 PM
#261
Thanks TB for sharing your MAF scaling values
I wish someone could find the correct location for REV LIMIT in ECUflash, that would be awesome to be able to increase it
Offline
Feb 27, 2009, 08:42 PM
#262
Drives: 03 Lancer OZ 16g
^+1 i agree
Offline
Oct 7, 2009, 08:49 PM
#263
Drives: a boostmobile
So any update on this? I seem to have similar issues too. I go a bit rich into boost then the car stumbles. After I let off the gas or shift the car stumbles again. In boost my wideband reads 11.0 AFR, idk if that's the max it reads or if that's what it really is. Right now I'm playing with maf size, scalings, fuel tables and ignition tables.
Some help please.
Offline
Oct 20, 2009, 08:25 AM
#264
Drives: IX MR SE
11:1 should not be the max that the O2 reads, but if you have an Innovate product, you may want to verify the scaling using LM Programmer.
If you log airflow Hz in EvoScan, you should be able to use that data to dial in the MAF scaling table. Basically, as airflow (boost) rises, you'll need to increase the MAF scaling table in that Hz range to compensate for the extra fuel needed.
Increasing the MAF size value will also help, but it will increase your load level across the board. The issue with this is that it can cause drivability issues since the cruise load increases and you technically crush the WOT resolution in the maps. Increase this value only if needed.
Offline
Tags
11v, afr, boost, boosting, car, change, ecuflash, evoscan, lancer, lean, line, map, octane, oz, vacuum  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
