If the FMIC you're considering is an air to air IC, then the benefits won't be any better than a CAI. Possibly worse than a CAI, because of the extra restriction from the IC. If it's a liquid IC (e.g. air to water), then you ~might~ see some benies over a CAI. However, I suspect them to be negligible on a N/A car.
__________________
Mods:
Injen CAI - TWM Short Shifter - Tein S-Techs - Tints: (F)35% (R)15% - Clear Bra - VG Sharkfin Antenna - ARS HL2 Front Lip - ARS HL Diffuser
Want List:
Camber Adjustment Bolts - Adjustable Rear Sway Bar - HID Projectors - Cat-Back Exhaust - Wheels & Tires - Analog Oil Press and Coolant temp guages
